The front door of your house is one of the first things that visitors see when they come to your home. Therefore, a beautiful set of hand made doors can have a significant visual impact to the “first impression” visitors have of your home. This quartersawn white oak front door is easy to make and is sure to improve the look of your home.
A door like this can be constructed in a number of different ways, many of them requiring heavy duty commercial tooling, and power feeders for precision milling. However, the construction method I describe here does not. This method greatly facilitates and speeds up the process, so that even if you don’t have a lot of experience, you can still make a great looking door.
When building a door the most important tool is your jointer. Although it’s an easy task to face joint, handling the long stiles can be a cumbersome task, so some additional care needs to be taken when you joint these pieces. It’s crucial that the rails be straight and flat in order to eliminate warpage of the door frame.
You can build the door with all solid wood or you can use a lamination of ½" plywood and ⅛" shop sawn hardwood veneer. The laminated technique has a couple of great advantages over the solid door version. It will be much more warpfree and more likely to retain its shape over the years. During the construction though, a dead-flat surface is absolutely essential for lamination glue-up. Also, since you’ll be using shop sawn veneer, you can virtually use any wood you like.
You will not have to use 8/8 (or 2") lumber and dress it down to 7/8 (1 ¾") thickness. The laminated version also eliminates the machining of 2" deep mortises and tenons, yet allows very tight fitting 5" to 6" deep mortise and tenons (with no machining at all). The only downside of the laminated version is that it takes longer to build. Available time versus available tools seems like the equation here, so suit it to your own condition. For these doors I used the laminated technique.
Cutting the Plywood
First, choose good quality ½" plywood. It needs to be flat with no tension in it at all. Follow the cutting diagram for the plywood. Please note the dimensions of this door are a standard 36" x 80" x 1 ¾". You can alter the measurements to suit your need.
Begin by ripping the upper and lower rails (UR1, UR2, LR1 and LR2). Then cut the center rails and finally the stiles (S). The cut-off pieces in the diagram, marked (F) are not scraps! Put them aside; they will be used as fillers on both sides of the centre rails (CR).
Cutting Parts to Size
All parts need to be cut with stops to ensure that their sizes are identical. A cut-off box is the perfect aid to accomplish this, unless you have a sliding compound mitre saw or radial arm saw. You may find it easier to clamp the stiles together when cutting them.
Gluing Tips
I use a painter’s 4" trim roller for applying glue. Apply the glue in a uniform pattern, as you would when painting a wall. This method creates minimal glue squeeze-out.
You can use an outdoor glue like LePage’s Outdoor Glue or Franklin’s Titebond III, or you can use a polyurethane glue. Personally, I like Titebond III’s longer open time (especially for this project). It also rolls on easily with minimal mess. You can keep the glue roller in a Ziploc bag. I’ve been keeping mine for the last six months in four or five different bags. The roller does not deteriorate and the glue doesn’t dry up.
Gluing Sequence
Apply glue to (F1) and (F2) only. First, glue down (F1) to the edge of (UR2). Then glue down (F2) to the other edge, using (CR) in between (F1) and (F2) as a spacer. You may use screws and/or nails to position all these pieces to prevent creep (as the veneer will cover the screws/nails). Once (F1) and (F2) are secured on (UR2) then position (CR) by checking with a ruler. Make sure that (CR) overhangs (UR2) 6" on each end. Once you’re happy with how (F1), (CR) and (F2) are glued on (UR2), you may proceed to glue (UR1), sandwiching (F1), (CR) and (F2) in between (UR1) and (UR2).
The Rails (horizontal door frame members)
Use one of the three edges as a reference, and make your cuts either on the table saw or with a router equipped with a bottom bearing flush-trimming bit. In the case of upper or lower rails, it’s wiser to use the centre piece (one of the (F) pieces) as a reference since the table saw fence or router bit bearing will ride on the longest and continuous edge.
Repeat the same process for the lower rail. Once both rails are laminated and trimmed, glue piece (E) to the outer edge of each rail (on the top edge of the upper rail and on the lower edge of the bottom rail). You may also screw and plug these solid wood pieces. Make sure you drill countersunk pilot holes first. Note that these pieces are oversize (1 9/16") and they need to be trimmed with a bottom bearing flush trimming bit. Once they are trimmed, glue your shop sawn veneers (⅛" thick) on both sides, together or one at a time. In case the plywood you have is undersized, increase your veneer thickness to 5/32" or thicker as required. The goal here is to reach exactly 1 ¾" thickness. After the veneers have been glued, trim the edges and it’ll be ready for the last step, creating the shoulders. An oversize mitre slot slider is the perfect jig to cut the shoulders. Simply butt the end of the tenons to the fence and trim cut the shoulders on your table saw. Make sure you don’t cut into the ‘built-in’ tenons.
The Stiles (vertical door frame members)
The stiles are more straightforward. Cut two of the six (S) pieces together down to 66 ⅞", making sure that the ends are perfectly square. These two 66 ⅞" pieces will make the centre layer of the left and right stiles by being sandwiched between the 80 ⅞" outer (S) pieces of plywood. You can use the cut offs on the end of the stiles, leaving them a little oversize; they will be trimmed once the frame is glued together. Glue the plywood layers, then the ⅜" edging and finally the ⅛" veneers the same way the rails are done. The ⅜" solid edging should only be glued, since they will be highly visible every time door is opened. You can use the completed upper and lower rails to check the fit of mortise spacing and overall symmetry of the pieces that make up the left & right stiles. That way, there won’t be any surprises when it all comes together.
On the stiles, don’t use the centre plywood piece as a reference edge for trimming, because it has spaces to accept the tenons. Use the outer top or bottom layers, since they have continuous edges. Also, for both rails and stiles, laminate the plywood layers first, trim and cut them to final size, then glue ⅜" solid edging on the outer edges of each piece. After trimming them out, apply the ⅛" veneers and trim them with router.
When all four members of the door frame are done, you’ll be amazed how tight those tenons slip into the mortises. No brute force is necessary, but the tight fit can create a vacuum when you want to take them out. Make sure you trial fit the pieces without using glue. You can drill some ⅛" holes into the tenon cheeks to facilitate glue distribution. I use polyurethane glue inside the mortises and put Titebond III on the tenons. This seems to create an excellent bond.
The Centre Panel
Now it’s time to fill the inside of the frame to complete the door. First, you’ll need to mill eight trim pieces (¾" x 9/16"). Trim four of them to about 66" or 67" and the other four to 24". These pieces are trimmed and glued inside the frame with a 1/16" reveal using a shop made gauge for consistent results. I pin these in place with a pneumatic air nailer using 23 gauge nails, which are hardly visible.
The next step is the centre panel. I used slats milled down to 1 ⅛" from 5/4 (1 ¼") stock. Their edges are grooved on the table saw with a dado ½" width by ⅝" deep. I milled the ends of these slots with my router, carrying the groove on all four sides. I also milled ½" x 2 ¼" x 66" strips, which went in between the slats (not glued, but free floating) and along the edges of the whole panel. Pay attention to the grain orientation of these pieces at the end of the slats.
Now you can drop the whole assembly on the glued trim, inside the doorframe.
Once everything is in place, apply the same strips on the other side, applying glue carefully on the trim or inside corner.
It helps to give some very shallow scoring cuts to the glued surfaces of the trim. This prevents glue squeeze-out.
You could also use plywood panels with insulation sandwiched between them, or raised solid panels.
I used Watco medium walnut stained Danish Oil, followed by Watco Marine Teak Oil. You can recoat the door with Teak Oil whenever is necessary.
If your door is facing the afternoon sun, you might want to increase the frequency of additional coats, or simply apply outdoor varnish or some other type of finish of your choice.
Use of Canadian Woodworking's Website and It's Content
This website is presented with the understanding that:
The authors, editors and related web personnel are not responsible for the results of any actions taken on the basis of information on this website, nor for any errors or omissions;
This website is not engaged in rendering professional advice/services; and
Any and all content submitted by this website's users is in no way an expression of the beliefs or opinions of the owners, webmasters, authors and editors.
Canadian Woodworking disclaims all liability for any claim in relation to:
• any matters or factors outside of its control, including the availability or unavailability of the website and digital content due to the availability of the Internet, or telecommunications or other infrastructure systems; for any reasons including but not limited to power outages and maintenance.
The owners, webmasters, administrators, authors and editors, expressly disclaim all and any liability to any person, whether a user of this website or not, in respect of anything and of the consequences of anything done or omitted to be done by any such person in reliance, whether whole or partial, upon the whole or any part of the contents of this website. Please exercise caution when working with any tools or machinery. Follow common safety rules and precautions as outlined in any manuals related to the equipment being used. If advice or other expert assistance is required, the services of a competent professional person should be sought.
Use of Canadian Woodworking site and Forum
By posting on this site and forum, the poster grants to Canadian Woodworking Magazine/Website the unrestricted rights to use of the content of the post for any purpose, including, but not limited to, publishing the posted material, including images, in print or electronic form in a future issue or issues of Canadian Woodworking magazine or related Canadian Woodworking products, and to use the post for promotional purposes without further compensation, as well as the right to use the poster's name in a credit along with the post.
CanadianWoodworking never shares, sells or rents your information to any third party without your permission.
This statement explains how we collect information from you and what we do with that information.
What this Privacy Policy Covers
This Privacy Policy covers CanadianWoodworking.com's treatment of personally identifiable information that CanadianWoodworking.com collects when you are on the CanadianWoodworking.com site, and when you use CanadianWoodworking.com's services. This policy also covers CanadianWoodworking.com's treatment of any personally identifiable information that CanadianWoodworking.com's business partners share with CanadianWoodworking.com.
This policy does not apply to the practices of companies that CanadianWoodworking.com does not own or control, or to people that CanadianWoodworking.com does not employ or manage.
Information Requests and Use
CanadianWoodworking.com collects personally identifiable information when you use certain CanadianWoodworking.com services, when you visit CanadianWoodworking.com pages, and when you enter promotions or sweepstakes. CanadianWoodworking.com may also receive personally identifiable information from our business partners.
Personally identifying information is information that can be used to identify who you are such as: name, mailing address, email address. To enter certain areas of the site, you will be required to register and provide information about yourself. This information is for the purposes of Canadian Woodworking and helps us to tailor the site to best meet the needs of our audience.
CanadianWoodworking.com also automatically receives and records information on our server logs from your browser including your IP address, CanadianWoodworking.com cookie information and the page you requested.
CanadianWoodworking.com uses information for three general purposes: to customize the advertising and content you see, and to fulfill your requests for certain products and services.
Promotions
The personal information that we retain is what is provided by you voluntarily. We use it to send you information about Canadian Woodworking and its products or to correspond with you regarding your subscription. If you are a subscriber we need this information to be able to deliver you our product(s) and service your subscription.
By completing a form on this website, you will be able to receive email correspondence from Canadian Woodworking. These emails may include information on upcoming events or special offers for subscribers. If you do not wish to receive email correspondence please email [email protected] and ask to be removed from our email list. Every email that we send to you will include an "opt-out" from receiving future email correspondence.
Aggregate information is information that cannot identify you personally. We collect information on our subscribers that may be used in summary reports presented to our advertisers. This information helps them to better understand our audience and provide advertisements that are more likely to be of interest to you and your organization.
Our intention is always to gather information that will help us serve you better and never to gather information without your knowledge.
As with most websites, we do log web visits. This information, however, does not have a link to you personally. These logs help us understand the needs of our audience and the areas of our site that you do or do not find useful. When you simply browse our site, no personal information is being collected. We may disclose this non-personal information to third parties such as sponsors, clients or advertisers.
Information Sharing and Disclosure
CanadianWoodworking.com will not sell or rent your personally identifiable information to anyone.
CanadianWoodworking.com will send personally identifiable information about you to other companies or people when:
We have your consent to share the information;
We need to share your information to provide the product or service you have requested;
We need to send the information to companies who work on behalf of CanadianWoodworking.com to provide a product or service to you. (Unless we tell you differently, these companies do not have any right to use the personally identifiable information we provide to them beyond what is necessary to assist us.);
We respond to subpoenas, court orders or legal process; or
We find that your actions on our web sites violate the CanadianWoodworking.com Terms of Service or any of our usage guidelines for specific products or services.
Cookies
CanadianWoodworking.com may set and access CanadianWoodworking.com cookies on your computer.
Cookies are small text files that most Web sites, including canadianwoodworking.com place on your computer. Cookies help us identify your interests. They also prevent you from having to register repeatedly on canadianwoodworking.com or from repeatedly seeing the same ads.
Canadianwoodworking.com is not able, and does not wish, to use cookies to track your activities on the Web outside of our site. And no cookie delivered by us will interfere with the operation of your computer.
In cases where there are links to other sites, Canadian Woodworking recommends that you review their organization's privacy policy, as once you have left our site you become subject to the privacy and security policies of the new site.
Third party advertising
If you submit your name through a form on our website to request information from an advertiser or third party, canadianwoodworking.com is not responsible for any marketing or other use of your name by that third party.
Security
In certain areas CanadianWoodworking.com uses industry-standard SSL-encryption to protect data transmissions.
Changes to this Privacy Policy
CanadianWoodworking.com may amend this policy from time to time. By using this site, you agree to the terms of this Privacy Policy. Canadian Woodworking reserves the right to make changes to this policy at any time. Please check back periodically to review any changes.
Questions or Suggestions
If you have questions or suggestions please contact us.
