I chose to do this little project because of the uniqueness of the material. The piece is actually comprised of a few different woods, but the main focal point is the elk antler, which makes up the body of the bowl. This project incorporates some box making techniques as well as bowl turning techniques.
The main bowl section is elk antler, the lid is African blackwood, and the foot is a combination of rosewood and serpentwood. It is the different textures and surfaces that add to this project's visual appeal.
Main Body
• Begin with the main body, which is the elk antler or 'button'. This is a very hard and brittle material. Start the piece using the tailstock for maximum support. Antler cuts well, but only with a very sharp tool. Shape the bottom first, as when shaping a bowl. The only difference is that now the tailstock is in play. I use a Sorby stebcenter, which makes it possible to turn down to the required dimension for the foot. The foot will later be used to hold the piece and facilitate cutting the inside of the bowl. Leave the natural edge on the antler button, as it adds a lot of character to the piece.
• Use a small ⅛" parting tool to cut the spigot that will serve to hold the piece. Turn a small bead on the bottom with the parting tool. You can change the angle of the tool, effectively making it into a skew, and roll the bead left and right. Following this, scrape the bottom cleanly and sand it smooth.
• Use a ¼" gouge to cut the inside. Again, use the tailstock for support until you get the edge of the inside hollowed out a bit. The tailstock is there for a reason; use it when you need it. Next, scrape the high spots on the inside. Because this material is very hard, it scrapes very well and sanding can be done with a fine grit.
Antler held with Sorby stebcenter
Cut the spigot with a parting tool
Cut the inside with a ¼" gouge
Lid
• With a very sharp square end scraper, scrape a recess that will accept the lid.
• Mount a piece of African blackwood between centers, true it up, and then size the lid. For this, use a parting tool, taking light cuts from the side until the lid fits snugly into the bowl.
• Turn the inside (tailstock side) of the lid slightly concave, then put it aside.
Scrape the high spots
Size the lid
Foot
• Mount the stock for the foot between centers and true it up with a skew. Use a chuck to hold the piece, and turn a recess to fit the spigot of the bowl. Then, part off a section of the piece. With the section still in the chuck make a jam chuck, reverse the foot onto it, and then turn the bottom of the foot.
• Back to the lid. With the same piece left in the chuck, turn the front surface slightly convex so that the inside of the lid will sit on the end. Next, apply double sided tape to this surface and attach the lid using the tailstock to line it up. Remember that at this point you are not taking a heavy cut, so the tape is quite sufficient to hold the piece. First shape the top, and then do any detailing with a skew or a 3-in-1 tool.
• Sand and polish the lid, bowl and foot. Glue the foot to the bowl and attach the lid.
True the foot with a skew
Turn a recess for the spigot
Part off a section
Make a jam chuck
Turn the bottom of foot
Detail the top
Sorby Stebcenter available at:
Lee Valley Tools LeeValley.com 1-800-683-8170
Use of Canadian Woodworking's Website and It's Content
This website is presented with the understanding that:
The authors, editors and related web personnel are not responsible for the results of any actions taken on the basis of information on this website, nor for any errors or omissions;
This website is not engaged in rendering professional advice/services; and
Any and all content submitted by this website's users is in no way an expression of the beliefs or opinions of the owners, webmasters, authors and editors.
Canadian Woodworking disclaims all liability for any claim in relation to:
• any matters or factors outside of its control, including the availability or unavailability of the website and digital content due to the availability of the Internet, or telecommunications or other infrastructure systems; for any reasons including but not limited to power outages and maintenance.
The owners, webmasters, administrators, authors and editors, expressly disclaim all and any liability to any person, whether a user of this website or not, in respect of anything and of the consequences of anything done or omitted to be done by any such person in reliance, whether whole or partial, upon the whole or any part of the contents of this website. Please exercise caution when working with any tools or machinery. Follow common safety rules and precautions as outlined in any manuals related to the equipment being used. If advice or other expert assistance is required, the services of a competent professional person should be sought.
Use of Canadian Woodworking site and Forum
By posting on this site and forum, the poster grants to Canadian Woodworking Magazine/Website the unrestricted rights to use of the content of the post for any purpose, including, but not limited to, publishing the posted material, including images, in print or electronic form in a future issue or issues of Canadian Woodworking magazine or related Canadian Woodworking products, and to use the post for promotional purposes without further compensation, as well as the right to use the poster's name in a credit along with the post.
CanadianWoodworking never shares, sells or rents your information to any third party without your permission.
This statement explains how we collect information from you and what we do with that information.
What this Privacy Policy Covers
This Privacy Policy covers CanadianWoodworking.com's treatment of personally identifiable information that CanadianWoodworking.com collects when you are on the CanadianWoodworking.com site, and when you use CanadianWoodworking.com's services. This policy also covers CanadianWoodworking.com's treatment of any personally identifiable information that CanadianWoodworking.com's business partners share with CanadianWoodworking.com.
This policy does not apply to the practices of companies that CanadianWoodworking.com does not own or control, or to people that CanadianWoodworking.com does not employ or manage.
Information Requests and Use
CanadianWoodworking.com collects personally identifiable information when you use certain CanadianWoodworking.com services, when you visit CanadianWoodworking.com pages, and when you enter promotions or sweepstakes. CanadianWoodworking.com may also receive personally identifiable information from our business partners.
Personally identifying information is information that can be used to identify who you are such as: name, mailing address, email address. To enter certain areas of the site, you will be required to register and provide information about yourself. This information is for the purposes of Canadian Woodworking and helps us to tailor the site to best meet the needs of our audience.
CanadianWoodworking.com also automatically receives and records information on our server logs from your browser including your IP address, CanadianWoodworking.com cookie information and the page you requested.
CanadianWoodworking.com uses information for three general purposes: to customize the advertising and content you see, and to fulfill your requests for certain products and services.
Promotions
The personal information that we retain is what is provided by you voluntarily. We use it to send you information about Canadian Woodworking and its products or to correspond with you regarding your subscription. If you are a subscriber we need this information to be able to deliver you our product(s) and service your subscription.
By completing a form on this website, you will be able to receive email correspondence from Canadian Woodworking. These emails may include information on upcoming events or special offers for subscribers. If you do not wish to receive email correspondence please email [email protected] and ask to be removed from our email list. Every email that we send to you will include an "opt-out" from receiving future email correspondence.
Aggregate information is information that cannot identify you personally. We collect information on our subscribers that may be used in summary reports presented to our advertisers. This information helps them to better understand our audience and provide advertisements that are more likely to be of interest to you and your organization.
Our intention is always to gather information that will help us serve you better and never to gather information without your knowledge.
As with most websites, we do log web visits. This information, however, does not have a link to you personally. These logs help us understand the needs of our audience and the areas of our site that you do or do not find useful. When you simply browse our site, no personal information is being collected. We may disclose this non-personal information to third parties such as sponsors, clients or advertisers.
Information Sharing and Disclosure
CanadianWoodworking.com will not sell or rent your personally identifiable information to anyone.
CanadianWoodworking.com will send personally identifiable information about you to other companies or people when:
We have your consent to share the information;
We need to share your information to provide the product or service you have requested;
We need to send the information to companies who work on behalf of CanadianWoodworking.com to provide a product or service to you. (Unless we tell you differently, these companies do not have any right to use the personally identifiable information we provide to them beyond what is necessary to assist us.);
We respond to subpoenas, court orders or legal process; or
We find that your actions on our web sites violate the CanadianWoodworking.com Terms of Service or any of our usage guidelines for specific products or services.
Cookies
CanadianWoodworking.com may set and access CanadianWoodworking.com cookies on your computer.
Cookies are small text files that most Web sites, including canadianwoodworking.com place on your computer. Cookies help us identify your interests. They also prevent you from having to register repeatedly on canadianwoodworking.com or from repeatedly seeing the same ads.
Canadianwoodworking.com is not able, and does not wish, to use cookies to track your activities on the Web outside of our site. And no cookie delivered by us will interfere with the operation of your computer.
In cases where there are links to other sites, Canadian Woodworking recommends that you review their organization's privacy policy, as once you have left our site you become subject to the privacy and security policies of the new site.
Third party advertising
If you submit your name through a form on our website to request information from an advertiser or third party, canadianwoodworking.com is not responsible for any marketing or other use of your name by that third party.
Security
In certain areas CanadianWoodworking.com uses industry-standard SSL-encryption to protect data transmissions.
Changes to this Privacy Policy
CanadianWoodworking.com may amend this policy from time to time. By using this site, you agree to the terms of this Privacy Policy. Canadian Woodworking reserves the right to make changes to this policy at any time. Please check back periodically to review any changes.
Questions or Suggestions
If you have questions or suggestions please contact us.
