Turn a Corkscrew and Bottle Stopper Combo
Turning Project: If you like wine and pizza, this turning project is for you. Fire up the lathe, then get ready to uncork the wine.
corkscrew_lead
Photos by Gavin Villa; Lead photo by Rob Brown
INFO:DIFFICULTY – 2/5, LENGTH/TIME – 2/5, COST – 2/5SPECIAL TOOLS – KIT
Required accessories:
• 7 mm long mandrel
• 3 pc bushing set (#BS6-BU)
• 7 mm drill bit (#PK-7mm)
• Barrel trimmer system (#PKTRIMKIT)
• Two-part epoxy glue or cyanoacrylate glue
Learn more about the corkscrew bottle stopper kit here:
penblanks.ca/instructions/english/BS7-THandleStopper.pdf
I was able to get all the supplies for this T-handle bottle stopper from William Wood-Write (penblanks.ca), which saved me a lot of grief. Though I picked up a stainless steel bottle stopper kit and a deluxe jumbo pizza cutter kit as well, they were too simple to make to include in this article. If you order through their website, be sure to click on the “Related Products” tab and it will list the required bushing set, 7 mm bit, and 7 mm mandrel shaft.
You’re going to need two blanks of the wood of your choice that are at least 3/4" square and 2" long. This is a perfect project for that piece with the wild grain you tucked up in your secret stash (yeah, you know the one I’m talking about). I chose a piece of zebrawood.
corkscrew_1
Cut the blanks to size
To start, cut two blanks that are the length of the supplied brass tubes plus add an extra 1/16". Next, drill the hole for the brass tube. Find the center by twice marking corner to corner diagonally, creating an X. Chuck up a 7 mm bit in your drill press and drill completely through the center of both blanks. To accurately drill the holes, I used a very simple jig, which allowed me to clamp the blank in place to hold it steady and square. The jig is nothing more than a plywood base and two blocks screwed together. Another option would be to use a drill press vise.
Once you have your holes drilled through your blanks, glue a brass tube in each blank. You can use either an epoxy or cyanoacrylate (super glue). Epoxy gives you a longer open time to finesse the tube right where you want it, but most kinds take a few hours to cure enough to be able to turn. Super glue, on the other hand, dries and is ready to turn in a matter of seconds. The downside is that this also only gives you a few seconds to insert the tube. The potential of it possibly ruining my precious blank and me having to order a replacement tube to start over prompted me to decide on a quick-curing epoxy.
It is important to only glue the outside of the brass tube. If you put glue on the inside of the blank hole as well, you run a very high risk of getting glue inside your tube while you insert it. This can be a real pain when you try to mount the blank on your mandrel. Keep in mind it only requires a very small amount of glue to bond the blank and tube.
corkscrew_2
Drill the Blanks – Villa made a simple fixture out of a piece of 3/4” plywood and two wood blocks to secure the blanks while drilling them out for the brass tube.
corkscrew_3
corkscrew_4
Glue it In – Epoxy allows for a more relaxed assembly, while CA glue makes for a quick but unforgiving assembly. Villa chose epoxy for his stopper, just to be on the safe side. He lightly applied it to the outer surface of the brass rod, but didn’t apply any to the inside of the drilled hole. This ensured epoxy wouldn’t end up inside the brass rod, causing problems down the road.
Twist and wait
As you insert the tube, use a twisting motion to help distribute the glue and prevent plunging it all out the other end. Position the tube in the blank so you have the same amount of excess wood on both sides (1/32") and then leave it be for the glue manufacturer’s recommended cure time.
When the glue is dry use your 7 mm barrel trimmer to square up the ends of the blanks. This step is very important to get nice seamless joints when the project is assembled. If you do not have a barrel trimmer (as I do not), I was able to carefully use a mitre gauge with an auxiliary fence on my disc sander. To able to do this, your hole must be drilled parallel with the registering face of your blank. If not, you will end up with unsightly gaps. Having done it the hard way, I would definitely recommend investing the $15 on a barrel trimmer.
Now set up your 7 mm mandrel on your lathe. If you cut both blanks from one piece of wood, be sure to keep track of the order when mounting them so the grain will match up upon final assembly. Working from left to right, first slide 3-4 spacer bushings, followed by a cap bushing, one blank, then the center bushing, the second blank, the second cap bushing, then finally however many spacer bushings needed to fill the space to the threads. Bring the tailstock in and lock it in place and advance the live center then tighten the locking nut on the mandrel to secure all the parts.
corkscrew_5
Flush the Ends – If you don’t have a barrel trimmer you can sand the ends of the blanks flush. Just be sure the ends of the blank finish perpendicular to the brass rod.
corkscrew_6
Rough it Out – With the parts assembled, Villa roughs out the blank with a gouge.
Start turning
I used a medium gouge to rough out the shape and followed up with a large skew to even out any high spots. The bushings are the same diameters as the end caps and body of the corkscrew, so turn the wood as close in diameter as possible to them. Finish up by sanding with your method of choice. For me, the finish off the tool was fine enough that I was able to start at 220x and decided to end at 600x. As a final step, burnish the surface with shavings to create a nice silky smooth finish, and then remove all the parts from the mandrel.
corkscrew_7
Smooth it Out – Villa uses a skew to even out the surface of the blank, and to bring it down just about flush with the bushing.
Finish then assemble
It is important that you finish the wood before assembly. You may use whatever finish suits your fancy. Since the corkscrew isn’t going to be eaten from and is going to be subject to having a noxious red liquid dye (wine) occasionally come in contact with it, I chose to finish it with three light coats of wipe on polyurethane to give it a durable finish.
To assemble the corkscrew/bottle stopper, put a small drop of either epoxy or super glue on the shaft on either side of the head and press on the barrels. Put a drop on each end cap and press them in on either end. I carefully used a small brass hammer with a softwood block to prevent marring the chrome to initially seat the pieces, then put the whole assembly into my front vise (with wood jaws, as not to mar the surface) and slowly pressed everything together. Be sure to clean up any glue squeeze-out now.
After the glue sets, the final step is to open a nice bottle of your chosen beverage with your new opener, pour yourself a drink, cork it with your new stopper and sit back and appreciate your work.
corkscrew_8
Ready for a Finish – Once the overall shape has been determined, sand the wood smooth with your desired grit. You can then take some shavings and burnish the surface of the wood while the part is still turning on the lathe.
GAVIN VILLA
Gavin Villa
When not busy filling his shop with shavings, or fiddling with planes, Gavin will most likely be found on the local lakes and rivers with fly rod in hand.
King 12" Jointer/Planer Combo
Shop News: The King Industrial 12" Jointer/Planer Combination European-style machine offers the capabilities of both machines, without compromising your workspace
Radley 20V Drill/Driver Combo Kit From Home Hardware
Shop News: This 20V lithium ion cordless drill driver/impact driver kit (1239-151) includes a 20V drill, 20V impact driver, 1-hour charger, 2 batteries and a tote bag.
Bottle Openers: 3 Takes on a Theme
Weekend Project: There’s nothing like a nice cold one after some time in the shop. Make one (or all) of these bottle openers and you can reap the rewards of your shop time with each drink you enjoy.
