3/8” x .032” x 3TPI Saw37GT Bandsaw Blade
Shop News: This special heavy set, hard tooth, bright carbon steel bandsaw blade from R&D Bandsaw is for high volume production environments.
This special heavy set, hard tooth, bright carbon steel bandsaw blade from R&D Bandsaw is for high volume production environments such as furniture manufacturing and/or any other applications where high feed rates and output is crucial. The heavier set pattern creates extra clearance and allows contours to be cut more efficiently in a high output production process. Hook ETS. Great for bowl turners. Visit TuffTooth.com for details.
R&D Bandsaws 3/4" Woodslicer Swift Blade
Shop News: With a 3–4 variable pitch, this blade has the aggressiveness of a 3 tooth and a surface finish of a 4 tooth.
Bandsaw
Know Your Tools: Get the most out of your bandsaw.
Reduce Dust From Your Bandsaw
Dust Collection: These days, most of the bandsaws produced by the major manufacturers have some sort of hook-up for dust collection. However, most of them are set up for vacuum cleaner hook-ups and are usually not of sufficient size...
