Forrest Woodworker II 7-1/4" Rip Blade
Shop News: Forrest’s dedicated 30-tooth Woodworker II ripping blade yields surprisingly smooth cuts right from your saw, eliminating the need for second-step finishing.
From our supporting advertisers
Forrest’s dedicated 30-tooth Woodworker II ripping blade yields surprisingly smooth cuts right from your saw, eliminating the need for second-step finishing. It’s perfect for low-resistance, easy-feed ripping of soft or hard woods of any thickness, and for fast ripping of plywood sheets without splintering the veneer. The 7-1/4" diameter, thin kerf version is designed for lower-power handheld circular saws. Its standard bore fits 5/8" and diamond-shaped arbors. It also removes 25% less material than other blades. Retail price of $95.00 for the 7-1/4" makes it an affordable—and highly useful—addition to your shop. Visit ForrestBlades.com for more information.
RazorTooth – The Ultimate Finishing Blade
Shop News: Any time a project requires truly fine finishing blades, the Exchange-A-Blade RazorTooth line is the one to choose.
Selecting and Using a Saw Blade
Shop Essentials: The quality of a cut is largely determined by the saw blade you’re using, and how you’re using it. For most woodworkers, selecting a blade is where the mystery begins. Let’s remove the mystery and provide you with...
Saskatchewan Woodworkers' Guild Exhibition
Shop News: Each year, the Saskatchewan Woodworkers’ Guild puts on an exhibition showcasing the work of its members, as well as the work of students who are under 18 years old.
