Little Ripper Bandsaw Blade - Canadian Woodworking Magazine
Shop News: When re-sawing or cutting straight we recommend our 5/8» x .025» x 3 or 4 TPI high tungsten impregnated silicon hardedge hardback blade.
From our supporting advertisers
When re-sawing or cutting straight we recommend our 5/8» x .025» x 3 or 4 TPI high tungsten impregnated silicon hardedge hardback blade. It will make cuts faster and cleaner than a normal bandsaw blade. The extra hard tooth stays sharp longer and cuts straighter. It performs like a wider blade, but uses less HP to run, as it has a thinner body than a standard re-saw blade and cuts extremely smooth. For optimum performance blade speed under 3100 LFPM a 4 TPI is recommended, and over 3100 LFPM should be 3 TPI. Visit TuffTooth.com for more information.
Open a Little Library at your Home
Community Project: If you’re looking for a way to get to know your neighbours, and show off your woodworking skills, this project is for you. The little library movement is gaining strength, and woodworkers everywhere are playing a...
Reduce Dust From Your Bandsaw
Dust Collection: These days, most of the bandsaws produced by the major manufacturers have some sort of hook-up for dust collection. However, most of them are set up for vacuum cleaner hook-ups and are usually not of sufficient size...
Saw Blade Holder
Shop Project: This blade holder will not only protect your sharp saw blades, and keep them well within arm’s reach, but it also won’t interfere with the regular use of your saw.
