RazorTooth – The Ultimate Finishing Blade - Canadian Woodworking Magazine
Shop News: Any time a project requires truly fine finishing blades, the Exchange-A-Blade RazorTooth line is the one to choose.
RazorTooth
Any time a project requires truly fine finishing blades, the Exchange-A-Blade RazorTooth line is the one to choose. Thanks to the hyper sharp tooth design, RazorTooth blades provide the user with ultra-smooth, chip-free cutting, which reduces the need for sanding. These blades are ideally suited for cutting melamine, laminates, hardwoods and even laminate flooring. RazorTooth blades are available in a wide variety of diameters and tooth configurations. The popular Professional Series is designed to meet the exacting standards of the contractor and finish carpenter, while the General Purpose Green Series provides a value-priced blade for the DIY customer. For more information on these ultimate finishing blades please go to ExchangeABlade.com
R&D Bandsaws 3/4" Woodslicer Swift Blade
Shop News: With a 3–4 variable pitch, this blade has the aggressiveness of a 3 tooth and a surface finish of a 4 tooth.
3/8” x .032” x 3TPI Saw37GT Bandsaw Blade
Shop News: This special heavy set, hard tooth, bright carbon steel bandsaw blade from R&D Bandsaw is for high volume production environments.
Diablo Multi-Purpose Carbide Saw Blades
Shop News: Available in both 7‑1/4" x 36 tooth and 6-1/2" x 32 tooth versions, Freud's Diablo blades will have you covered in almost any situation you find yourself in.
