Freud 10" Ultimate Cut‑Off Blade
Superior crosscuts on your table or miter saw.
This Ultimate Cut-Off blade's teeth actually polish the material as it cuts. New laser-cut anti-vibration slots practically eliminate the vibration that resonates in standard blades, producing glass-smooth finishes. With a finish this perfect you won’t need stabilizers.
  • Premium TiCo HI-Density Carbide Crosscutting Blend for Maximum Performance
  • No Stabilizers needed
  • Unique Side Grind polishes the material to produce a superior finish
  • Perma-Shield Non-Stick Coating reduces blade drag, protects the blade from corrosion and pitch build-up.
Ideal For: Ultimate crosscutting blades for glass-smooth finishes when crosscutting hard and soft woods, so no sanding is required. Depth of cut (1/4" min to 1-5/8" max)
FreudTools.com
The Ultimate Router Table Revisited
Shop Project: This router table was built 20 years ago and has stood the test of time, although over the years a few minor shortcomings have been realized. Learn how the original was built and how to tweak a new build so it’s...
Little Ripper Bandsaw Blade
Shop News: When re-sawing or cutting straight we recommend our 5/8» x .025» x 3 or 4 TPI high tungsten impregnated silicon hardedge hardback blade.
Freud Tools
Premium Carbide Saw Blades, Drill Bits, and Router Bits.
