Hot Products 2019 - Canadian Woodworking Magazine
Hot Products 2019: With the wide selection of new products that come out annually, it can be overwhelming to have to keep up to date with everything that hits the market. To make this task easier on Canadian Woodworking & Home Improvement readers, we have assembled this list of “Hot Products” to kick off 2020.
Cuz D Circular Saw
Hot Products 2019
cuz-d-#B3835
The Ultimate Circular Saw
The Cuz D Straight Flush Cut Saw #B3835 is a revolution­ary design that allows flush cutting, under cutting, and cutting into 90° corners – with a maximum cut depth of 3-1/8". With the Cuz D you can cut into and out of corners; set the blade to a negative 5° bevel and the blade is lifted away from the wall, so finished walls are not dam­aged; gang cut two 2". 4" boards in just one pass; and cut a 6". 6" beam with just two passes. This saw is built to compete, out-perform and out-last. Available exclusively in Canada at Busy Bee Tools.
BusyBeeTools.com
Video
armor-auto-adjust-clamp
Self-Adjusting Pocket Hole Jig
No more manual setting, measuring, or adjusting. The Auto-Adjust clamp allows you to clamp varying thicknesses without readjusting. Simply put your work piece into the patented Armor Auto-Adjusting Clamp and the Auto-Jig will do the rest. The color coded screw system with Color-Coat technology makes it easy to match the screw size and head to the thickness and depth of the pocket hole, while the color coating itself offers anti-corrosive protection to your work piece.
Armor-Tool.com
Video
DAP-wood-pro
DAP-wood-pro
The All Purpose Latex Wood Filler
Cracks, gouges, holes and other surface defects happen. But with DAP WOODPRO you don't have to worry. This high quality, latex-based indoor/outdoor wood filler is formulated to create a surface and body that looks and acts like real wood. You can use it for repairs on furniture, woodwork, moulding, cabinets, panelling, plywood, windows, doors and painted surfaces. This easy-to-use filler is low in odour and cleans up with water. The thick, knife-grade formula can be moulded and sculpted making it ideal for corners, vertical and unsupported surfaces. It offers easy handling by spreading smoothly and evenly. When dry, DAP WOODPRO can be sanded, cut, planed, drilled, nailed or screwed, stained and painted. It's shrink, crack, and crumble resistant and provides strong nail and screw anchoring.
Canada.Dap.com
DAP-wood-pro-x
Wood Filler That Goes on Pink and Dries Natural
A distinct advantage of DAP WOODPRO-X is that it goes on pink so you can easily see the areas you're repairing, but dries to a natural colour. The colour change lets you know when WOODPRO-X is cured, ready to be sanded, stained, or painted. It's low in odour and cleans up with water. This all purpose high quality, latex-based wood filler is formulated to create a surface and body that looks and acts like real wood. Use it to repair cracks, gouges, holes and other surface defects on indoor or outdoor furniture and woodwork, as well as moulding, cabinets, panelling, plywood, windows, doors and painted surfaces. The thick, knife-grade formula can be spread smoothly and evenly, and easily moulded and sculpted for corners, vertical and unsupported surfaces. Once it's dry WOODPRO-X can be sanded, cut, planed, drilled, nailed or screwed, stained and painted, and it's shrink, crack, and crumble resistant.
Canada.Dap.com
Video
steel-city-planer-35-215S3
Cast Iron Construction Minimizes Vibration
The heavy duty 3 HP Steel City 15" planer (#35-215S3) is a solid workhorse. A 3 HP motor delivers feed speeds of 16 and 20 ft/min, serviced by a long lasting oil bath lubricated gear drive. The 3 straight knife cutterhead delivers smooth, clean cuts, while the 48" cast iron table makes it easy to feed long, heavy stock. The motor and cutterhead move on 4 posts for optimal stability. Includes a knife setting guide.
SteelCityMachines.ca
steel-city-air-filter-80-100
Improve Your Workshop Air Quality
Filter up to 98% of 5 micron airborne particles and up to 85% of 1 micron particles with the Steel City 3 Speed Air Filter (#Model 80-100). The 1/3 HP motor delivers superior 2-stage air filtration with user selectable speeds of 700, 900 and 1250 CFM. This system cycles all the air in your shop 23 times every hour (based on a shop size of 20’ x 20’ x 8’). It includes a remote control for convenient operation and a filter cleaning sensor with indicator light to let you know when the filters need cleaning.
steel-city-80-210CS3
Reliable and Efficient Dust Management
A dust collector is one of the most important machines in your shop removing the wood chips produced at source by your shop machinery. The Steel City 80-210 series of 2 HP dust collectors are available with bag, canister, or HEPA cartridge filters.  The heavy-duty motor, designed for continuous industrial applications, delivers an airflow capacity of 1,550 CFM. These units feature a precision balanced, spark free aluminum impeller for smooth operation and minimal noise.
normand-centurion-sliding-table
Add a Slider to Your Table Saw For Efficient Panel Processing
A sliding table saw enables you to rip and crosscut large panels, quickly, efficiently, and safely. The Centurion Sliding Table attachment is available in a 40" (# 12144) and 60" (#12146) capacity. They can be installed on almost any 10" to 14" table saw. The units are built with heavy duty tubular steel for maximum stability, and slide on ball bearings for smooth operation. All adjustment levers are indexable - no key is required. Includes a 54" crosscut fence that can extend beyond 91" with the extension.
Normand.ca
normand-centurion-blade-cover-12210
Telescopic Blade Cover With Integrated Dust Collection
The Centurion Table Mounted 10" Blade Cover (#12210) provides an excellent barrier to protect your hands from the table saw blade as well as an effective dust collection system to remove dust from the top of the saw. The unit is easily installed on any table saw. The boom provides 30" of travel so you get 66" clearance to the right of the blade. The blade cover is suspended over the blade and does not cling to stock like most protectors. There is no need to remove the blade cover when you want to rip narrow pieces or make rabbet or dado cuts.
Normand.ca
steel-city-jointer-#30-300HS3
Full Featured Jointer with Helical Cutterhead
With its 24 dual sided replaceable cutter head knives the 2HP heavy duty cast iron Steel City 8" Jointer (#30-300HS3) delivers consistently clean, chip-free cuts. It features an extra long 75-3⁄4" cast iron infeed/outfeed table with a 1⁄2" rabbeting capacity, cast iron fence with angle stops at 0° and -/+45°, lockable magnetic switch, and hand wheels with retractable handles.
rubio-monocoat-pre-aging
Give Your Wood Floors That Beautifully Aged Look
If you're looking to give your new, or 'soon to be refinished' wood floors a smoked, fumed or aged wood look, then pre-treat the wood with Rubio Monocoat Pre-Aging. It's a high-quality, non-reactive water-based pre-treatment, available in 10 standard shades. The colour spectrum ranges from a lighter to a darker look. The colours can be mixed with each other to get just the right shade you want. The result is a deep colour with subtle accents. Application is easily done manually with a sponge, roller, or by spraying, and once dry, you can topcoat with the Rubio 2C oil of your choice. Available in 100ml, 1L, 5L and 25L sizes.
RubioMonoCoatCanada.com
Video
trend-stealth-respirator
New Generation Low Profile Respirator
The light and compact Trend Stealth is a new generation N100 half- mask respirator with dramatically improved features that will benefit users in low and strenuous activities for extended periods of time. It provides a 99.99% filter efficiency (to 0.3 microns) due to a special HEPAC filter material (exclusive to Trend) in combination with a unique protective grill that deflects dust away from the dual filters. The downward facing exhaust valve greatly reduces fogging of glasses and shields. The Thermoplastic Elastomer (TPE) special medical grade material moulds to the face immediately and the unique one strap pull mechanism keeps the mask secure and snug. This unique blend of features makes the Trend Stealth  over 3 times easier to breathe with than other N100 half masks. Available in Small/Medium and Medium/Large sizes. N100 replacement filter pairs are available individually and in five packs.
Trend-UK.com
Video
kutzall-shaping-wheels
The Must-have, Most Versatile Angle Grinder Accessory
When it comes to freehand carving on your larger projects, no other tool gets the job done better than Kutzall Shaping Wheels. Paired with a quality right angle grinder, these wheels have helped skilled craftsmen create truly remarkable things. The rugged tungsten-carbide coating allows for superior material removal and outstanding wear-life. Minimal clogging and effortless control, you’ll use them project after project.
Kutzall.com
Video
kutzall-hand-rasp
The Ultimate Man-Powered, Hand Shaping Instrument
Kutzall Hand Rasps strike a fascinating bal­ance between the shaping and smoothing function of a conventional file and the aggressive stock removal of a wood rasp. Each rasp is made with a rugged tungsten-carbide coating, providing you with an aggressive, multi-directional tool that will cut effi­ciently, resist loading, and stay sharp project after project. Available in flat, half-round and warding.
Kutzall.com
bora-PM-8000
bora-PM-8000-2
Combination Saw Stand and Workstation
Whether you need a portable miter saw stand, or extra work surface, the compact BORA Portacube STR Miter Saw Workstation (#PM-8000) is the perfect addition to your work space. Its compact footprint of 31" × 29" stores easily in almost any workshop. The built-in extension wings give you up to 7' of working surface when fully extended, while the adjustable tool tables rise to the height of the miter saw — from 2" to 4-1/2". One of the most unique features is the rotating tabletop. The universal tool mounts allow it to fit almost any miter saw up to 26-1/2" wide. You can also mount bench top planers or other benchtop power tools. When you're done with your cuts it easily rotates your miter saw back into storage. Sturdy 10" wheels roll the Portacube around your shop or jobsite.  This is the ideal workstand for workspaces of any size. Now available through Home Depot CA!
BoraTool.com
Video
home-hardware-flooring-shear-1076-046
Cut Flooring Accurately and Dust-Free
With the Home Hardware 13" Flooring Shear (#1076-046) you can quickly and accurately cut luxury vinyl and plank, laminate, and engineered wood indoors without producing any dust or noise.  These shears will slice material up to 1" thick (with a Janka hardness of up to 1300) with a single motion of the handle. A built-in ruler provides for accurate cutting. Blades can be re-sharpened and replacement blades are available.
HomeHardware.ca
benchmark-tirbore-1245-488
Drill Faster - For Longer
The innovative design of the new Home Hardware TirBore (#1245-488) drill bits enable you to drill faster and the bits to last longer. The patented 3rd flute on the drill bit better dissipates heat (increases the lifespan of the bit) and more efficiently removes debris out of the hole resulting in faster drill times. The set consist of 13 bits, from 1/16" to 1/4".
HomeHardware.ca
melamine-saw-blade-1110462
Perfect Cuts for Melamine, Laminates, and Plastics
The 60 C2 carbide teeth on this Melamine Saw Blade (#1110462) are set in a TCG (Triple Chip Grind) tooth pattern with a 15° hook angle to deliver extra fine, chip-free cuts on high density manufactured materials. These blades last longer, not becoming dull as fast as standard FTG blades. As part of the EAB Exchangeable Program, when these blades become dull or damaged, simply return them to your dealer for an Exchange Credit that you can apply towards your next EAB purchase.
ExchangeABlade.com
sandpro-SBP108
Sanding With Downdraft Tables
If you want a cleaner, healthier workshop, then you need to collect dust at the source with a downdraft sanding table. They're portable, durable, quiet, and powerful. SandMan Products LLC has tables to suit the needs of hobbyist woodworkers, small professional shops, Superior and large production shops. For objects too large for sanding tables there's the Sand Pro Sanding Booth SBP108 – a complete self-contained 9,300 CFM backdraft unit. With the Sand Pro Inspection Light you can easily see scratches, swirl marks, and other imperfections before the material is finished.
SandManProducts.com
SC_website_bessey_lead_2018-09
Award Winning BESSEY GearKlamp
The GearKlamp from BESSEY is a first of its kind in the world. It easily reaches places that were previously difficult or impossible to access. This unique clamp is all made possible by a patent pending mechanism that allows the separation of the spindle from the handle and, where the handle is positioned around the rail. This innovative design offers a surprisingly comfortable clamping position and permits applications in places where traditional clamps would not be practical. Available in 6", 12", 18" and 24" clamping capacities.
BesseyTools.com
Video
fein-e-cut-carbide-pro
Cut Through What Other Blades Can’t
Titanium Nitride (TiN) coated hard metal plunge-cut saw blades provide outstanding wear resistance and much higher service life compared to non-coated hard metal saw blades or HSS saw blades. The FEIN E-Cut Carbide Pro BiM TiN offers strong cutting performance and quality for just about everything you use in your shop: hardwoods, sheet goods, ferrous metals, stainless steel, copper pipes, tempered screws (Spax), high-strength machine screws, as well as plastic, drywall, brick, masonry and cement fibre slabs. The one blade that cuts them all.
Fein.ca
Video
fein-multimaster-FMM350QSL
Still The Oscillating Tool of Choice
With a soft-start motor for super smooth speed acceleration, electronic speed control that delivers constant speed under load, exceptional build quality for maximum durability and long tool life, and the game changing QuickIN tool clamping system for super quick accessory changeover, it's no wonder the FEIN MultiMaster FMM350QSL is so popular among cabinet installers, renovators, finish carpenters, flooring installers, and trades people. Reliable, durable, unbeatable.
Fein.ca
Video
leigh-box-joint-B975
A Simple Jig That Makes Great Fitting Box Joints
The Leigh Box Joint & Beehive Jig B975 is a multipurpose box joint jig that is a simple and easy-to-use tool for making 1/2" and 3/4" box joints on boards up to 13/16" thick, and from 1-7/16" to 17-13/16" wide. Based on numerous requests from beekeepers, the B975 was also designed to make several sizes of beehive supers using 1/2" and 3/4" joints. The precision injected glass-reinforced nylon template is extremely durable, and the included elliptical e10 guide bushing is adjustable for recordable joint fit adjustment.
LeighTools.com
Video
scorpion-helical-jointer:planer
Combination Machines Give Great Value
If you have a small shop, a combination machine can be a worthwhile consideration. It enables you to get more machinery per square footage of shop space than conventional stand-alone machines. With the Scorpion 16” Helical Jointer/Planer you can both joint and plane stock up to 16" wide. And, the Stinger carbide helical five row cutterhead delivers crisp, clean cuts on any wood. Additional features include a swing away Euro guard, flush mount electrical panel with digital planer table height read- out, and an easy to use mobility kit.
CWImachinery.com
Video
magnum-MI-91400
Power and Precision for Ripping and Resawing
The Magnum Industrial Deluxe 14" Band Saw (MI-91400) can easily handle all your needs - from ripping and resawing to detailed radius work. A European-style one-piece frame and balanced cast iron wheels make for a steady and stable wood-cutting machine. Features include sealed guide bearings, a quick-release tensioner, deluxe fence system, and dual wheel speeds. In addition, its dual voltage motor draws only 10 amps at 120 volts, so you can plug it into a standard outlet.
KMSTools.com
magnum-MI-16250
Grind, Deburr, Sand, and Sharpen With Ease
The Magnum Industrial Benchtop Belt Sander/Grinder (MI-16250) is a versatile and reliable asset for any workshop. It features a sanding belt that pivots from 0 to 60°, and locks in at any angle in between. In addition, the 3/4 HP motor spins the 8" grinding wheel at 3,450 rpm, so you can finish metal, sharpen tools and more. Uses economical and readily available 2" x 48" abrasive belts.
KMSTools.com
magnum-smart-liner
Lay Out Perfectly Accurate Lines
With the Magnum Smart Liner Cross Line Laser, you can lay out flooring, tiles, ceilings, stairs, doors and windows with accuracy and ease. This laser emits two highly visible beams, one vertical and one horizontal, up to 164' (with a receiver). Its automatic self-levelling feature ensures the lines are dead-on accurate. The Smart Liner has a durable housing that has a dust and water resistant IP54 rating. Available with either red or green beams.
KMSTools.com
magnum-MI46150
Apply Perfect Edges on Sheet Stock
The Magnum Industrial Hot Air Edge Bander (MI-46150) can significantly speed up the process of covering the edges of sheet goods in the workshop or at the jobsite.  It features a smooth sliding teflon-coated table and guard, a Steinel double-insulated 1500 Watt heat gun that delivers up to 200°C, and a fence that supports banding up to 2-1/4" wide.
KMSTools.com
magnum-MI-81360
Minimal Tear-Out on the Most Problematic Hardwood
Equipped with a helical cutterhead with 22 carbide inserts, the Magnum Industrial 8" Jointer (MI-81360) is tough enough for commercial applications, yet right at home in smaller workshops. Featuring a rugged 2 HP motor and an extra-long (73") ground cast-iron table, this jointer is designed to deliver high-quality, accurate results time after time.
KMSTools.com
tekna-G3-chuck-bundle
Get Added Value with a Woodturning Chuck Bundle
With smooth geared action and a powerful grip, the NOVA G3 Chuck delivers steady, vibration-free performance on a variety of wood lathes with 1" x 8 TPI spindles and 14" swing. This reversible chuck is ideal for smaller lathes because it's light and compact. Yet it's also tough and accurate, made of machine-grade steel for durability and minimal runout. The included T-handle chuck key allows you to make adjustments with only one hand, and the chuck is compatible with a full range of NOVA jaws and accessories.
KMSTools.com
spektra-router-bits
Router Bits That Last the Longest
Spektra router bits feature a micro-thin ceramic coating that enables the tool's cutting edge to retain crucial sharpness and lubricity – with an up to 2.5 times longer life. The coating prevents high heat build-up and oxidation, which is detrimental to cutting performance. There are a range of cost effective Spektra bits to choose from for both CNC and router applications.
AmanaTool.com
Video
flexcut_starterset
Everything You Need to Start Carving
The Flexcut 3-Knife Starter Set KN500 has three of the most useful wood carving knives. The comfortable curved ergonomic handles allow for long periods of carving without hand fatigue. The set includes KN12 Cutting Knife, KN13 Detail Knife, KN14 Roughing Knife, and Flexcut Gold polishing compound. Value priced at $59.95.
Flexcut.com
hot_products_54
The Woodcarver’s Multi-Tool
The 6-blade Flexcut Carvin’ Jack JKN91 is the world’s first folding multi-tool for woodcarving. It’s equipped with 2 scorps, straight gouge, a hook knife, chisel, and a detail knife. You also get a slip strop, a bar of Flexcut Gold polishing compound to keep your blades sharp, and a leather belt-mounted sheath that looks good with jeans or even your better pants. It's a woodcarving set in your pocket. $164.95.
Flexcut.com
Video
flexcut-knife
A Spoon Carver’s Dream Tool
The Flexcut Spoon Carvin’ Jack JKN96 has both a shallow and a deep hook knife, designed to form the hollows of spoons and bowls. It also features a straight blade for shaping and carving fine details into the design. This tool fits neatly in your pocket, so you can carve wherever you go. The handle is made of rugged aerospace aluminum with an ergonomic design that contours to fit the palm of your hand. There is also deep crosshatching on the handle to keep the knife from slipping while carving. $128.95.
Flexcut.com
Video
rali-cut
Precision Mini Cut-Off Machine
The RALI Cut disk cutting machine is the perfect tool for making successive rapid, clean, and precise cuts on wood, steel, and plastic up to 25mm/.98" in diameter. It enables you to cut solid and hollow pipes and square stock, as well as shorten screws and bolts, and make a precise range of angle cuts with the angle cut accessory (sold separately). Also includes a deburring wheel that quickly deburrs and finishes.
TersaKnives.com
Video
purebond-aspen-plywood
Multi-Purpose Plywood
With a smooth sanded, flat, and consistent surface, Canadian-made FSC-certified PureBond Aspen Plywood is suitable for woodworking projects that will be painted – from cabinetry to closets, shelving, entertainment centres, tables, shelves, headboards, wall panels, and furniture. The light-weight, all-wood veneer construction also makes it the perfect substrate for veneering, high-pressure laminate, or other specialty surface treatments. These economically-priced 4' by 8' panels are available in 1/4”, 1/2” and 3/4” thicknesses, and made with soy-based, formaldehyde-free PureBond technology, so they won't degrade your indoor air quality.
CFPwood.com
Video
king-canada-KC-8200
Superior Cyclone Dust Collection
A dust collector is one of the most important machines in your shop. The powerful 2 HP motor on the King Canada KC-8200 with its 1,650 CFM suction capacity and 1-micon canister filter, removes wood chips and dust at source so your shop machines operate efficiently.  It features a 29 gallon drum capacity, flapper handle for cleaning the canister, two 4" dust ports, and remote control.  Also available are 1.5, 3 and 5 HP models.
KingCanada.com
king-canada-KC-1202FX
The Space Saving, Versatile Bandsaw
If you are looking for features in a value priced bandsaw, look no further than the King Canada KC-1202FX. This 12" open-stand bandsaw features a 3/4 HP motor that delivers speeds of 1,312 and 2,952 SFPM. It has a large 18-7/8" x 15-3/8" tilting table with rack and pinion adjustment. You get a 12" cutting capacity from the frame to the blade, and 6-3/4" re-saw capacity. Includes a cast aluminum miter gauge, rip fence with 5" high face, push stick, and adjustment wrench and hex keys.
KingCanada.com
king-canada-KC-1402FX
Full-Featured Bandsaw
The King Canada KC-1402FX offers just the right blend of precision, capacity, and power in a 14" bandsaw. It features an adjustable upper/lower ball bearing blade guide system, belt tension adjustment knob that makes it easy to release blade tension when the saw is not in use to help prolong blade life, a rack and pinion height adjustment system, a flexible LED light to increase work piece visibility, along with a cast aluminum miter gauge and rip fence with 5” high face.
KingCanada.com
king-canada-KC-2244DS
Affordable Drum Sanding
With the new King Canada KC-2244DS high performance drum sander you can sand up to 44" with a double pass, and 22" with a single pass, removing up to 1/64" per pass.  You can sand stock from 1/8" to 5" thick and as short as 2-1/4" long. The sander features a 5" diameter precision balanced aluminum drum, and a 1.75 HP motor that delivers a variable feed speed up to 31 feet per minute. A top mounted 4" dust port makes for efficient dust collection.
KingCanada.com
king-canada-KC-8379
The Quickest and Easiest Way to Sand Drywall
With the King Canada KC-8379 foldable orbital Drywall Sander you can quickly and efficiently sand large areas. The filter perimeter skirt allows air in, but traps the dust for superb collection. A 5 Amp motor delivers variable speeds from 600 to 1,500 RPM, and you get an 8-1/2" sanding pad diameter and 45" to 65" telescopic reach. Coupled with the King Canada HEPA vacuum (KC-8590TTV) you get close to dust-free drywall sanding.
KingCanada.com
king-canada-KC-8590TTV
Optimal At-Source Dust Extraction
The King Canada KC-8590TTV HEPA vacuum, with its three stage dry filtration system, delivers optimal at-source dust control for all your power tools and benchtop machines. And, it has dual auto-start/auto-off outlets so you can use it with electric and pneumatic tools. It features a 1,200 Watt, 10 Amp motor, 30L (8 gallon) corrosion resistant tank, air blower and manual self-clean functions. Includes dust bag, filters, hose, wand, and floor sweep.
KingCanada.com
forrest-woodworker-II
The Ultimate Table Saw Blade
The award-winning Woodworker II carbide-tipped 40-tooth general purpose table and circular saw blade delivers quiet, high quality rips, combos, and crosscuts up to 2" in hard and softwoods with a smooth-as-sanded surface and no bottom splintering. Specially-engineered clearances on the blade teeth eliminate side scoring. Available in 4-3/8" to 16" diameters, and priced from $87 to $207. Made in the USA, they come with a 30-day, money-back guarantee.
ForrestBlades.com
Video
freud-quadra-cut
Flawless Edge Profile Router Bits
The unique design of Freud Quadra-Cut router bits delivers an ultra smooth finish that doesn't need any sanding. Unlike conventional router bits, which have two cutters, Quadra-Cut bits have four cutters. Two large cutter wings shear upward to quickly remove most of the stock. Two smaller cutter wings shear downward for an ultra-fine finish – even when routing cross-grain in delicate materials – on both the top and bottom faces of stock. The result is, for almost any wood, and regardless of the grain pattern, a flawless finish without the need to rework the routed surfaces. Splintering and fuzzing are virtually eliminated. These bits feature Freud's TiCo (Titanium Cobalt) micro-grain, hi-density carbide for superior cutting life and performance. There are a range of decorative edge and rounding over Quadra-Cut router bits to choose from, singly and in convenient bit sets.
FreudTools.com
Video
fuji-mini-mite-5-platinum-T70
Powerful 3-Stage HVLP Spray System
Equipped with a Heat Dissipation Chamber that removes any heat build-up from the turbine case, and Noise Reduction Covers that reduce noise, the Fuji Spray Mini-Mite 3 PLATINUM is a real favourite with both professional and hobbyist cabinet and furniture makers. The 3-stage turbine, which develops approximately 6.5 psi, is powerful, portable, and perfect for all fine-finishing. Additional power allows the unit to be used with a range of high to low viscosity materials. The system is easy to operate and maintain. It includes a professional grade non-bleed spray gun with stainless steel fluid passages and comes with a full 2-year warranty on parts and labour.
FujiSpray.com
Video
sawstop-JSS-120A60
The World's Safest Jobsite Saw
The SawStop Jobsite Saw Pro (#JSS-120A60), is an upgraded version of the SawStop Jobsite Saw, a class-leader in innovation and safety. New features for the PRO model include a deeper table, Active Dust Collection Blade Guard, versatile high-low fence, plus a host of other ways to work faster, smarter and safer at your next jobsite. The new 24-1/2"+ deep table surface delivers ample support for larger rip and cross-cuts, helped by a 25-1/2" rip capacity. The new included Active Dust Collection Blade Guard captures blade turbulence to collect and evacuate above-table dust. Advanced under-table shrouding maximizes dust extraction for a cleaner, safer work area. SawStop’s T-Glide Fence is unmatched, with smooth lockdown and easy adjustment. Now, attach the new quick-change low fence for safer rip cutting of smaller work pieces.
SawStop.ca
Video
oneida-air-dust-free-router-hood
Simple and Effective Router Dust Control
The Oneida Universal Dust-Free Router Hood captures nearly all the wood chips and dust produced by hand held routers from both above and below the bit. It virtually eliminates post-project cleanup, facilitating fine detail work, and reducing wear and tear on bits. Molded from clear polycarbonate it offers excellent clarity and superior durability. It’s designed to work with most of the fixed base and plunge style routers from major brands, and comes with multiple, snap-on chip covers for edge, shallow edge, and inset routing. Tame the Dust!
Oneida-Air.com
Video
CNC-SHark-HD5
Robust and Feature Rich CNC Routing
The new CNC Shark HD5 has everything you need for quick set-up and running, and it's built with industrial grade components in the USA. Use it with your 2-1/4HP router or a NextWave Automation water-cooled spindle [not included]. The HD5 is available in a standard size with an XYZ travel of 25'' x 25'' or in an extended size with an XYZ travel of 25" x 50". Both include the exclusive Virtual Zero Unlimited software and Vectric VCarve design software (the extended comes with VCarve Pro) and have lifetime technical support.
NextWaveAutomation.com
Video
orion-smart-moisture-meter-950
Accurate and Dependable Moisture Measurement
The Orion Smart Moisture Meter 950 is the pinnacle achievement of the Orion line, designed for professional wood flooring installers/inspectors, quality control managers, restoration professionals and serious woodworkers who need superior accuracy, versatility, and ruggedness in their critical moisture measurement instruments. The Orion 950 continues Wagner’s 50-plus year tradition of providing accurate, dependable, non-damaging pinless moisture measurement technology, measuring IN the wood, not just ON the wood, and backed by Wagner’s industry-leading 7-year warranty. The Orion 950 interacts through Bluetooth technology with a free mobile app for your Android or Apple smart device. It provides readings at 1/4" and 3/4" depth modes to measure the moisture content of thin samples such as wood floors or deeper into thick wood samples. You can quickly obtain the ambient temperature and relative humidity measurements of any room with its built-in sensor, and the Orion 950 calculates and displays the current dew point when needed. It will also calculate if a wood specimen is at the critical threshold where it has reached its equilibrium with the environment and will no longer gain or lose moisture.
WagnerMeters.com
Video
smart-logger
Accurately Measure Temperature & Humidity
The Smart Logger is a small, lightweight, easily portable and highly accurate monitoring device that tracks ambient temperature and humidity conditions when you are away from the job site or workshop. It can also be utilized during the wood acclimation process and the storage of wood. The Smart Logger is capable of storing up to 12,000 pieces of data over a period of up to 300 days. It incorporates the latest Bluetooth technology and works in tandem with the Smart Logger app, which can be downloaded for free at the Apple Store or Google Play. The app connects the Smart Logger to your mobile device enabling you to transmit and record data, and even send reports via email.
WagnerMeters.com
Video
worx-mini-circular-saw
Mini Circular Saw With a Big Bite
The WORX 4.5A Slim Handle Mini Circular Saw is compact in size and features a streamlined body for excellent manoeuvrability and portability. Its slim grip with an integrated safety trigger provides comfort, balance and control. You get an exceptional 2" depth-of-cut and bevel adjustment of 0 to 45°, while the left-sided blade design provides great cut-line visibility.
CanadianTire.ca
Video
worx-4A-versacut-mini-circular-saw
The Versatile Mini Circular Saw
The WORX 4A Versacut Mini Circular Saw with its 3-3/8" blades is ideal for cutting a variety of material including wood, metal, and tile. The slim, ergonomic design is easy to manage and maneuver. Depth of cut is easy to set, while a laser indicator helps align cuts precisely. A convenient plunge cut indicator shows the exact position of blade entry. Includes a 24T TCT blade, HSS blade and diamond disc.
CanadianTire.ca
Video
worx-3A-sonicrafter-multi-tool
One Tool – A Myriad of Uses
The WORX 3A Sonicrafter Oscillating Multi-Tool Kit is ultra-versatile. With it you can cut, saw, scrape, sand, grind, and polish, on just about anything - wood, metal, plastic, ceramic, drywall, and more. It features variable speed control, and a universal interface that fits all brands of oscillating accessories. A Hyperlock tool-less blade holding system offers quick blade changes and helps prevent blade slippage, while a multi-angle adjustment feature adapts to different applications.
CanadianTire.ca
Video
worx-5
Hands-Free Table Top Jig Saw
With the WORX 5.5A Bladerunner Portable Table Top Saw your hands are free to manipulate your material rather than the tool, making accurate 0 to 60° angled and curved cuts so much easier.  It has a 3/4" stroke length, and uses standard T-shank jigsaw blades and has a built-in, flip-up door for convenient blade storage. A traditional guard and riving knife system allows unlimited capacity for cross and rip cuts. Its light weight and compact design offers hassle-free set up at your work site or in the shop.
CanadianTire.ca
Video
record-CGV286-3
A Huge Step Up From a Shop Vac
The Record 1000W Compact Extractor (#CGV286-3) provides a 36 litre capacity and an airflow of 54 liters per second, making it ideal for smaller workshops or on the jobsite. It features a CamVac triple cyclonic filtration system for effective treatment of fine particles down to 0.5 micron in size. The lid has an acoustic outlet for the motor – when a 2-1/2" dust hose is fitted, the sound of the motor can be directed away from the machine, greatly reducing noise in the workshop.
StockroomSupply.ca
record-CGV336-4
Full-Featured Mid-Size Dust Extractor
For shops that generate a lot of wood chips, the Record 2000W Medium Extractor (#CGV336-4) provides a 55 liter capacity and an airflow of 108 liters per second. Like its little brother, the Record 1000W extractor, it features a CamVac triple cyclonic filtration system and an acoustic noise reduction outlet on the lid.
StockroomSupply.ca
record-CGV383-6
Large Capacity, Outstanding Suction
With an impressive capacity of 90 litres and an air flow of 162 liters per second, the Record 3000W Large Extractor (#CGV383-6) can handle all but the most demanding shop environments. As with other Record CamVac extractors, it has a triple cyclonic filtration system for effective treatment of fine particles down to 0.5 microns. It also features an acoustic noise reduction outlet on the lid that enables you to divert noise away from the extractor.
StockroomSupply.ca
record-carving-set-RPCV12A
Get Carving with this Fabulous 12-Piece Set
This Record Carving Chisel Set (#RPCV12/A) comes with a brand new set of 12 basic chisels – all the profiles you need to start carving. It also comes with an excellent DVD and booklet from internationally acclaimed carver and teacher Mike Davies. This DVD features his Significant Six carving techniques that will form a solid foundation on which you can build your woodcarving skills in a logical and easy to understand fashion. Plus, you get a 16-page full colour booklet containing a collection of projects to put your skills to the test.
StockroomSupply.ca
Video
record-coronet-lathe-16007
Features, Power and Performance Second to None
The brand new Coronet Herald Heavy Duty Cast Iron Electronic Variable Speed Lathe (#16007) from Record Power features innovative design solutions – like state-of-the-art 1HP motor, full electronic variable speed from 95 to 3,890 RPM, and 360° rotating and repositionable headstock – that extend its capabilities, features and performance far beyond anything a lathe of this size has been capable of before. Turn bowls up to 21" diameter and 20" between centers (an extension bed is available).
StockroomSupply.ca
Video
SC3-scroll-chuck-package-61062
Lightweight and Compact Scroll Chuck Package
The SC3 Geared Scroll Chuck Package (#61062) is designed for the woodturner that wants a premium chuck with no compromise in performance and at the best possible price. It uses the same scroll and jaw carriers as the SC4 and has a smaller body because the scroll is engaged through a hole in the side of the body using a traditional chuck key. Includes deep wood screw, 50 mm standard jaws and 3.5” faceplate.
StockroomSupply.ca
Video
SC4-scroll-chuck-package-62063
Professional Geared Scroll Chuck Package
For the demanding woodturner the SC4 Geared Scroll Chuck Package (#62063) is designed to hold large work pieces yet possesses the precision and compactness to handle more delicate work. This model features an enclosed back with full indexing plate and has pinions driven by a long ball ended hex key to make access easy, even when large work pieces are mounted. This chuck is an insert model (the relevant choice of insert is included in the package) which means it's easily future proofed against upgrades and can be used on lathes with different spindle threads.
StockroomSupply.ca
Video
35mm-standard-jaws-62321
Jaws for Smaller Spigots and Recesses
These 35mm Standard Jaws (#62321) feature the same dovetail profile in expansion and the superb grip of the hawk beak design on contraction as the larger 50mm jaws. Designed specifically for smaller spigots and recesses, this set is incredibly versatile and makes a great addition to any turner’s tool collection.
StockroomSupply.ca
Video
50mm-standard-jaws-62313
Versatile Standard Chuck Jaws
These 50 mm Standard Jaws (#62313), which feature a specialised dovetail profile in expansion and superb grip of the hawk beak design on contraction, are a great all-round set, capable of bowl work to a good size and also spigot turning.
StockroomSupply.ca
100mm-dovetail-deep-gripper-jaws-62329
Jaws for Medium Size Bowls
Featuring a deep body and internal teeth to improve versatility with a specialised dovetail profile, these 100 mm Dovetail and Deep Gripper Jaws (#62329) are ideal for turning large bowls, green timber and hollow vessels. The outer dovetail jaws are ideal for large bowls or platters, particularly when gripping onto a spigot and the deep internal toothed body is ideal for large spigots of hollow vessels.
StockroomSupply.ca
130mm-dovetail-jaws-62317
Jaws for Large Bowls
Featuring a specialised dovetail profile, the 130 mm Dovetail Jaws (#62317) are ideal for turning bowls up to 30". They also feature a reverse dovetail for a contracting grip on large spigots.
StockroomSupply.ca
Video
75mm-bowl-gripper-jaws-62322
Jaws for Heavy Bowls and Vases
For heavy bowls and vases these new 75 mm Heavy Bowl and Gripper Jaws (#62322) are ideal. The wide front face provides a good register for the base of the bowl or vase and the deep toothed body provides strong grip on the spigot. The internal gripper can also be used on smaller rough green timber. Also featuring an external dovetail in expansion, they can be used for large platters. A truly versatile and solid jaw set.
StockroomSupply.ca
Video
long-nose-jaws-62323
Multi-Purpose Long Nose Jaws
These Long Nose Jaws (#62323) feature internal and external dovetails for bowl work. The deep internal grip is versatile but the main benefit of these jaws is to project the work away from the chuck, allowing good tool access to the base of the timber for cleaning and shaping.
StockroomSupply.ca
Video
pin-jaws-62327
Secure Spigot Grip for Smaller Work
The new Pin Jaws with 9 mm Bore (#62327) have been improved by squaring the external shoulder to allow work pieces to properly register against the back of the jaws. This is ideal for gripping pieces such as pepper, salt grinders, finials, and lace bobbins. This set is ideal for miniature turning and to grip work pieces internally without excessive damage or marking.
StockroomSupply.ca
Video
mini-spigot-jaws-62336
Strong Internal Grip for Smaller Items
The Mini Spigot Jaws with 13 mm Bore (#62336) have extra screw hole profiles and added teeth to the outside that provide tremendous grip for when this area will not be visible in the finished work piece. This set has a 13 mm internal diameter, making it ideal for turning strong spigots on knobs and handles, again adding to their versatility.
StockroomSupply.ca
Video
pen-jaws-62337
Accurately Drill Pen Blanks
These Pen Jaws (#62337) eliminate the need for a drill press. They deliver much more accurate results and their deep grip to all four sides ensures incredible holding power. Drilling on the lathe means the feed speed of the drill bit is under your complete control, meaning a superior finish can be achieved on a wide range of materials. These jaws are also useful for working on small finials and similar projects as in addition to their strong grip, the work piece is moved forward from the chuck, allowing greater access.
StockroomSupply.ca
Video
87mm-faceplate-ring-62572
Hold Medium Turned Blanks
This 87mm (3.5") Faceplate Ring (#62572) is ideal for holding medium sized bowl blanks, especially when you want to be able to remove and remount the blank. Due to its strong hold it's also suitable for out of balance timber. The ring is held to the chuck using the standard 50 mm jaw set (which comes standard with all Record Power chuck packages).
StockroomSupply.ca
Video
126mm-faceplate-ring-62574
Hold Large Turned Blanks
This 126mm (5") Faceplate Ring (#62574) is ideal for holding large bowl blanks and due to its strong hold is also suitable for more out of balance timber. It is held to the chuck using the standard 50 mm jaw set (which comes complete with all Record Power chuck packages.)
StockroomSupply.ca
Video
remounting-jaws-mini-62356
Remount Blanks Up to 200mm
Remounting jaws are incredibly popular due to their flexibility. These Remounting Jaws Mini - Up to 200 mm Bowl (#62356) work in both contraction and expansion modes and can be fitted behind other jaw sets to create custom setups to make turning more efficient. The soft stoppers are designed to hold without causing damage, making them ideal for remounting finished or partly finished objects for further work.
StockroomSupply.ca
Video
remounting-jaws-mega-62377
remounting-jaws-mega-62377-2
Remount Blanks Up to 275mm
The Remounting Jaws Mega with Buffer Kit (#62377) can be used with lathes that have a 12” swing capacity and are capable of holding bowls up to 275mm in contraction mode. They work in both contraction and expansion modes and can be fitted behind other jaw sets to create custom set-ups to make turning more efficient. The eight soft stoppers are designed to hold without causing damage, making them ideal for remounting finished or partly finished objects for further work.
StockroomSupply.ca
Video
RP-plastic-soft-jaws-62378
Make Your Own Custom Jaws
These RP Plastic Soft Jaws (#62378) are designed specifically to be cut with standard turning tools. They can be easily shaped to create custom jaws to fulfil exacting requirements and offer excellent grip without marking the work piece. Made of nylon.
StockroomSupply.ca
Video
SN_record_2019-10
record-power-extractors
Online Catalogue
Browse or download the new Record Power Tool Catalogue at CanadianWoodworking.com/Record2019
jorgensen-EZHOLD-bar-clamp-33412
The "Look, Ma! One Hand!" Clamp
The Jorgensen E-Z HOLD Expandable Bar Clamp (#33412) allows for rapid and easy clamping and can easily be converted to spreader clamps. It opens to a full 12", has a 3-3/8" reach, and a 300 pound clamping force. The contoured comfort grip and quick-release lever make it simple to get a firm grasp, and an exclusive patented feature lets you join two clamps together to create a clamp with more than double the opening capacity of a single clamp. Deep-reach pads help protect your work.
PonyJorgensen.com
Video
pony-spring-clamp-#3203-HT
Instant, Easy, One-Hand Clamping
When you need instant, easy application and removal, turn to the proven durability of the classic Pony Spring Clamp (#3203-HT). They provide a 3" opening with a 3" reach. Throughout the clamp’s range of opening, the point of pressure always remains at the lightweight, zinc-plated steel jaw tips to ensure they’ll hold it together exactly where you need them. Poly-vinyl protected handles and jaw tips mean you can use them on metal, wood, plastic, fabric, and beyond. And their contoured handles won’t dig into your hands.
PonyJorgensen.com
Video
jorgensen-steel-bar-clamps-3700
The Essential Shop Clamps
Bar clamps are a fundamental shop accessory, and Jorgensen Steel Bar Clamps (3700 series) are seriously strong. Cast-iron stationary and sliding heads with an orange, powder coated finish are merged with a high-carbon, rust-resistant steel bar that packs a whopping 80,000 pounds per square inch of tensile strength. The fast-acting sliding head is acme-threaded to accommodate a cold-drawn steel screw with a large easy-grip handle and swivel pad. A multiple-disc-clutch design allows the sliding head to hold securely at any point along the bar. Available in a wide variety of sizes and clamping forces.
PonyJorgensen.com
Video
pony-cabinet-claws-#8510
Quick and Easy Face-Frame Clamping
Complete your cabinetry projects in a fraction of the time with Pony Cabinet Claws (#8510). This unique and patented tool combines the various steps of face-frame cabinet installation into one easy process. The high-quality aluminum claws and alignment plate have protective rubber pads to cushion and protect cabinetry.
PonyJorgensen.com
Video
pony-light-duty-c-clamps-2600
Light Duty, Powerful Clamping
Super handy to have around the shop, and competitively priced, it's no wonder that Pony Light-Duty C-Clamps (2600 series) are the most popular and complete line of light-duty C-clamps on the market. The smoothly cut, acme-threaded steel screw is zinc plated and protected with a black finish for lasting durability. And the clamp casting is made with ductile iron for strength before receiving a powder-coated Pony-orange finish. Available in a wide variety of sizes and clamping forces, all with full-closing screws.
PonyJorgensen.com
Product #2600 series (click “Hobby” under “Specs”)
Video
pony-pipe-clamp-#50
The Classic 3/4" Pipe Clamp
The iconic Pony 3/4" Pipe Clamp (#50) has become North America’s most popular and widely used pipe clamp fixture design. The original steel multiple-disc-clutch design allows a secure hold and instant adjustment at any point along the pipe, without fear of slipping or pipe crushing. Use any length of 3/4" pipe, as long as the pipe is seven inches longer than your workpiece. Crafted with strong, durable iron castings and featuring a 1-3/4" clamping face.
PonyJorgensen.com
Video
Hot Products 2010
Sponsored Content: With the wide selection of new products that come out annually, it can be overwhelming to have to keep up to date with everything that hits the market. To make this task easier on Canadian Woodworking & Home Improvement readers...
Hot Products 2015
Hot Products 2015: With the wide selection of new products that come out annually, it can be overwhelming to have to keep up to date with everything that hits the market. To make this task easier on Canadian Woodworking & Home...
Ryobi, Senco and Ridgid Products
New Tools
