Milescraft Circle Guide Kit
Rout circles from 1-1/2" to 52" diameter.
Cut small and large circles from 1.5” in diameter to 52” in diameter with the CircleGuideKit. With the included TurnLock base plate, this product is compatible with most routers. There is no longer a need for that homemade router circle jig, the CircleGuideKit does it all for you and includes everything you need to cut your desired circle. This router guide also includes a BONUS Offset Base for finishing edges on your workpiece. Best used with a plunge router.
Small Circle Router Jig
  • Built-in imperial and metric scales, with an easy readout window for setting the diameter of both your inside and outside cuts
  • Quickly and easily attaches to the included TurnLock circle guide head
  • With this router guide, you can cut circles from 1.5″ to 12″ in diameter
Large Circle Router Jig
  • With this router guide, you can cut circles from 10″ to 52″ in diameter
BONUS Offset Base
  • 13” offset base provides added stability when finishing the edges on your workpiece using your router
  • Oversized handle knob is easy to grip providing superior control of your router
Milescraft.com
Cordless Vac, Belt Sander, & Laser Guide
New Tools
Bandsaw Circle Cutting Jig
Shop Project
FasTTracK Circle Jig Kit
Shop Tested
