Belt Sanders - Canadian Woodworking Magazine
Know Your Tools: These aggressive sanding machines can work wonders in the shop if you know how to handle them.
Belt Sanders
Belt Sanders
Photos by Rob Brown; Illustration by Len Churchill
A belt sander takes a bit of time to get to know well, but once you've mastered its use it will make quick work of much of your rough sanding tasks around the workshop. Belts, ranging from 36 grit to 150 grit, can be easily removed and added, giving the user a wide range of uses. If you're using a belt sander quite often a light yet powerful model, that feels comfortable in your hands, is what you want. Some battery-powered models are now available, though corded models are still the norm. Small units, called palm sanders, are essentially small belt sanders that can be used single-handed.
belt-sanders-1
belt-sanders-2
belt-sanders-3
Get the Most Out of Your Belt Sander
Select the Right Grit
Low-grit sanding belts are very aggressive, while higher-grit belts can produce a fairly fine and smooth surface. A high-grit, that's asked to remove too much material, will clog quickly and may cause burning.
Extra Care On Veneer
Belt sanders can eat through a layer of veneer in seconds, if not used with care. A light touch and putting the unit down gently before pulling the trigger is a good start.
Get Dedicated
Setting up a specific area in your shop where you can sand panels and longer lengths of material can help greatly. A stop to keep the workpiece in place is very helpful.
Know When to Stop
Know when to use a belt sander, and when a lighter sander is the best tool for the job. Belt sanders are typically one of the first to be used, while finer sanders provide a surface worthy of a great finish.
Dust Protection
Sanding dust accumulates quickly, so empty the attached dust collection bag often. To keep the ambient dust down a fan, an open door / window and dust mask / respirator can go a long way to keeping your lungs happy.
Price: $80 - $300
Amps: 5 – 10
Common Belt Widths: 3" and 4"
Common Belt Lengths: 18", 21" and 24"
Weight: 5 – 15 lb
admin_icon_articles
Random Orbital Sanders (JuneJuly 2017)
Table Saws (FebMar 2016)
Random Orbit Sanders
Shop Tools: If you've never tried a random orbit sander (ROS) before, you'll be amazed. It is the one sander I use most in my workshop for finish sanding. In fact, with the proper technique, a random orbit sander gives you finish...
Sanders
Short Cuts
Oscillating Spindle Sanders
Shop Tools: Whether sanding curves or straightening edges, look to the oscillating spindle sander for a smooth performance.
