Bosch Daredevil Framing Blades Deliver Precision and Speed
productnews_1
Ranging in size from 6 ½" to 8 ¼", the new Bosch Daredevil framing blades bring a number of things to the construction site every day: C3 micrograin carbide, thin-kerf, extra-hard steel plate blades, control-cut shoulders for reduced kickback and expansion slots to control blade warp. All these characteristics come together to deliver a combination of speed and a smooth finish. Add to all this Bosch’s Speed Coat finish, which avoids binding when you’re using treated or wet lumber, and you have yourself a great framing partner. “This blade is designed to start sharper and stay sharper − that’s beyond a tagline; it’s what framers asked for,” said Chris Carlson, Bosch group product manager, circular saw blades. To learn more or to find a local dealer, visit boschtools.com. —Rob Brown
Premium Blades For Precise Cuts
Get clean, accurate cuts on your table saw or mitre saw by using premium blades specifically designed for the job at hand.
Two-Sided Blades Are Great Value
Upgrade your planer or jointer cutterheads with easy and quick to install two sided replaceable Tersa knives.
Diablo Multi-Purpose Carbide Saw Blades
Shop News: Available in both 7‑1/4" x 36 tooth and 6-1/2" x 32 tooth versions, Freud's Diablo blades will have you covered in almost any situation you find yourself in.
