General International Pen Turning Lathe
Product News
productnews_1
General International’s new three-speed lathe (25-010) has been designed and built specifically for turning pens and other small hobby type projects. It’s equipped with a quiet ⅕ HP 110V 1.2 amp motor and features an extruded aluminum frame, head and tailstock. The maximum distance between centers is 12".
Both the tool rest and tailstock are equipped with smooth action quick lock ratchet levers for smooth, easy repositioning and positive locking action. The headstock spindle thread is ¾" x 16 TPI with a ⅜" through-hole to accommodate a large variety of standard after-market accessories, and both the head and tailstock are fitted with a very common MT#1 Morse taper.
Factory supplied with a 6" tool rest, 2 ½" face plate, live center, spur center, knock-out bar, a see-through lathe guard and a pen-turning mandrel set, this mini-lathe is currently retailing for $229.99 (pricing valid until at least August 31st, 2011) and can be ordered from most General/General International retail distributors.
See general.ca for a complete list of distributors.
Introduction to Hollow Turning
Wood Turning: There are many forms and techniques for hollow turning and this introduction will only take a quick look at one of them. Once you try hollow turning, you may want to look into it a little further.
Bench Top Lathe
Shop Tool
Preparing a Blank for Segmented Turning
Turning Jig: At first thought, accurately making segments for a turned segmented bowl seems like a tedious and painful task. That’s not the case, because a special mitre sled simplifies cutting the parts, while some standard supplies...
