King Laminate Trimmer - Canadian Woodworking Magazine
productnews_1
Laminate flooring is very tough, wreaking havoc on blades. This laminate flooring cutter from King Canada makes short work of cutting laminate flooring, engi­neered wood and even vinyl siding. It will handle product up to 13" wide and 19/32" thick, and makes absolutely no dust or noise. The sturdy steel and aluminum cut­ter has a long handle for increased leverage and will cut angles up to 45¼. Weighing in at 14 lbs., this unit is great for taking to jobsites or hauling around your home as you work. $139.99. For more information, visit kingcanada.com
Prize Winner!
productnews_2
Thomas Neil, right, with Scott O’Dell, owner of Home Hardware in Maple Ridge BC. Thomas won a TradeMaster 10" Sliding Compound Mitre Saw from Home Hardware.
Battery-Powered String Trimmers
Tool Comparison: We take a look at the wide selection of battery-powered string trimmers between 36 and 58 volts that are on the market this spring.
Working With Laminate
Shop Skills: Learning to work with laminate is a skill that can help you refurbish your home's counters or jazz up a shop work surface or jig.
Miter Trimmer
Tool Test
