Selecting and Using a Saw Blade - Canadian Woodworking Magazine
Shop Essentials: The quality of a cut is largely determined by the saw blade you’re using, and how you’re using it. For most woodworkers, selecting a blade is where the mystery begins. Let’s remove the mystery and provide you with the information needed to select the correct saw blades for your next project.
sawblade_lead
Photos by Rob Brown (Illustrations by Len Churchill)
Saws date back at least to the Egyptians, who used copper handsaws up to half a metre long. The Greeks and Romans improved the basic design by introducing wooden frames to support the blade. They also set the saw teeth alternately in order to get a more accurate and easier cut. The big breakthrough came after 1650, when the process of rolling wide strip steel was developed in Sheffield and Holland. Wider bladed saws made it possible to do away with the wooden frame, and the steel handsaw, as we know it, was born. It was discovered along the way that different blades were needed for different cuts. As furniture and joinery work became finer and more detailed, specialist saws were developed to help the craftsmen achieve the desired effect. Sash, tenon and dovetail saws with thinner blades, finer teeth and a steel or brass strengthening bar or back began to appear. Rip-cutting a long board using a handsaw was labour-intensive and a blade was needed to make the job go faster and easier. Along came the rip-cut saw. It was discovered that cross-cutting a board using a rip-cut saw was far less than satisfactory so along came a cross-cut saw. We now have the basis for a rip-cut blade and a cross-cut blade and this knowledge was transferred to circular blades.
The first circular saw was invented in 1777 and is credited to Samuel Miller of England. Miller created a metal disk with teeth around its edge, and discovered that at fast speeds the disk was very adept at cutting. His spinning saw blade would eventually be used in sawmills to cut lumber. It did not use electricity, and it was not portable. From the sawmill concept came a number of inventions that would allow an individual to cut lumber without the need to take lumber to the mill.
One company that marketed table-mounted saws was W.R. & John Barnes, of Rockford, Illinois. Its design was similar to a sewing machine; the user would pump a pedal to make the blade spin. These treadle-power designs were sold as early as 1878. In 1922, Raymond Dewalt created the first circular saw with a radial arm. Art Emmons, of Porter Cable, invented the first portable circular saw in 1929. His saw used a helical drive with an electronic motor.
sawblade_terminology
Four main types of blades
A) Rip-cut blade
B) Cross-cut blade
C) Combination blade
D) Triple-chip grind blade
sawblade_FT
sawblade_ATB
sawblade_ATBR
sawblade_TCG
Hook angle
The “hook angle”, also commonly referred to as the “rake angle”, is a term used to describe the direction of the blade’s teeth, as compared to the rotation and central axis of a saw blade. If you drew a line through the center of the blade and extended it to the cutting edge of each tooth, and the cutting edge of each tooth fell exactly on the line, then this would be a zero-degree hook angle. A positive hook angle would mean that the tops of the teeth are angled towards the direction of rotation, while a negative hook angle would mean they are angled away from the direction of rotation. The higher the hook angle (positive hook), the more aggressive and faster the saw blade will cut; however, the trade-off is a rougher cut. Hook angles of more than 20° should only be used for ripping. A negative hook angle is better for cross-cutting since the negative face of the tooth is much less likely to cause tear-out. A negative hook angle is good for making mitre cuts on moldings, cutting plywood panels, or cutting non-wood materials, such as plastics and metal. Angles between -2° and -10° are recommended for plywood, MDF, OSB, laminate, melamine, and particleboards.
sawblade_1
sawblade_2
Hook Angle – Different hook angles are appropriate for cutting different materials. Generally speaking, a positive hook angle (top) will cut faster, but leave a rougher surface. A negative hook angle (bottom) will produce a slower, but smoother cut.
Thick vs. thin kerf
The kerf of a blade is the overall thickness of cut the blade produces. There are advantages and disadvantages to both thick or thin kerf blades. A thin kerf blade is generally 3/32" wide and a thick kerf blade is generally 4/32" (1/8") wide.
As a general rule, thin kerf blades should be used with large and accurate saw collars or stabilizers for strength and accuracy, and are not recommended for deep cutting. Thin kerf blades can be very useful in fine woodworking since they offer low-resistance cutting, lower waste, and generally a good finish.
Attention must be paid to setting the blade height or depth correctly, and they should never be used on unstable or green material. Take extra care to keep the feed rate smooth while using a thin kerf blade. Due to its thinner plate, thin kerf blades dissipate less heat caused by friction. Since a thin kerf blade requires less horsepower, it may be a good choice for lower-powered saws and especially battery-powered circular saws.
There are many advantages, and a few disadvantages, to using thick kerf blades. Thick kerf blades are stronger and more resilient. They can also withstand repeated sharpening better than the narrower cutting blades and can make deeper cuts in thicker materials. The heavier mass of a full kerf plate will handle the stresses of heat better than a thin kerf blade, so it’s often a more suitable choice for volume applications. I have personally found that a thick kerf blade used in a 12–15 amp 7-1/4" or 7-1/2" circular saw performs better when used in conjunction with any track or guide system. Depending on the thickness of material to be cut, you may have to slow down the feed rate to compensate for any saw with lower horsepower. This is because thick kerf blades remove more material, and require more energy to maintain proper RPM.
A note about carbide teeth
People often think that carbide is carbide, but this is not the case. There are a number of different grades of carbide, which determine how long the blade will stay sharp, how clean it will cut, and how many times it can be re-sharped. On most premium blades the carbide is formulated specifically for the application of the blade. At a minimum, look for a blade with C3 grade micro-grain carbide teeth. C4 carbide is the most durable grade for saw blade teeth, and is usually found on premium blades. Generally speaking, the thicker the carbide, the more times it can be re-sharpened.
sawblade_3
Expansion Slots – Many blades have expansion slots to allow the blade to expand and contract slightly, without throwing the blade out of true.
sawblade_4
Large Carbide – Premium blades will generally have larger, higher quality carbide teeth, and can therefore be sharpened more times.
Rules of Thumb when selecting a table saw, mitre saw or circular saw blade:
  • Blades with more teeth yield a smoother cut. Blades with fewer teeth remove material faster, but tend to produce a rougher cut with more “tearout”. More teeth means you will need to use a slower feed rate
  • No matter what type of saw blade you use, you will likely wind up with residue on the saw blade. You’ll need to clean off this residue using pitch solvent. Otherwise, your saw blade will suffer from “blade drag” and can produce burn marks on the wood.
  • Do not use a rip blade to cut plywood, melamine or MDF. This will result in poor cut quality with excessive “tearout”. Use a cross-cut blade or, even better, a good-quality triple-chip blade.
  • Never use a rip blade in a mitre saw as this can be dangerous and will provide very poor-quality cuts. Use a cross-cut blade.
  • If you plan to cut a large volume of a particular material, it may be best to purchase a blade specifically designed for that material. Most manufacturers supply user guide blade information. Naturally, all blade manufacturers think their blades are the best, so you can also refer to the information above to further assist you.
  • If you do not want to change blades frequently and you constantly cut a variety of material, as is the case with many people, it may be best to stick with a good-quality combination blade. The average tooth count is 40, 60, and 80 teeth. The more teeth, the cleaner the cut, but the slower the feed rate.
Rules of Thumb for using a saw blade:
  • The blade depth above or below the material to be cut should not exceed 1/4". This setting creates less friction, resulting in less heat build-up and provides less resistance when pushing material through. A general misconception is that a deeper setting will give better and straighter cuts.
  • Never force any blade to cut faster than it is designed to. When using a lower-powered table saw or circular saw, listen to the motor. If the motor sounds like it is “bogging down,” then slow down the feed rate. All saws are designed to cut at a particular RPM and work best at that RPM.
  • With any table saw blade, remember that the teeth above the table’s surface rotate in the direction of the operator and enter the top surface of the work piece first; therefore, place the wood with the finished side upward. This would be the opposite when using a radial arm saw or circular saw. This applies to plain plywood, veneers, and any form of plywood with laminates attached. When both sides of the wood are finished, use a fine-tooth blade with minimum set or a hollow-ground blade.
  • Dull or damaged blades pose a danger. Regularly inspect your blades for any defects such as missing tooth tips, residue build-up and warping.
Woodworking is a wonderful occupation or hobby, but over 60,000 people are seriously injured using table saws every year. Remember that familiarity breeds contempt. The more one uses a saw, they tend to become overconfident, which is when accidents can happen. Never remove any safety equipment from your saw. Always use eye protection, feather boards, hold down devices and push sticks properly.
One of the leading causes of accidents results from inadequate infeed and out-feed tables or rollers. The natural reaction is to grab the panel or board when it falls and this would generally be right over the blade of the saw. Work safe and work smart and you will have many years of woodworking enjoyment.
roger_hamblen
ROGER HAMBLEN
Roger has two passions in life: design engineering and woodworking. He works a lot but never forgets his third passion, his wife, even if she always seems to have a “Honey Do” list longer than his arm.
Table Saw Blades
Tool Review
Saw Blades
Saw Blades - Download this handy poster that you can put up in your workshop for practical tips on saw blades.
Housing for the Birds
Craft Project: One of the pleasures of watching as the landscaping in our yard progresses over the years and the plants mature is the increasing frequency of visits by various species of songbirds. Watching them can...
