I have used both left- and right-tilt table saws over the years but when it was time to purchase a saw I would spend the rest of my life with, the choice was easy: right tilt. There are pros and cons to both but unless you are doing things most woodworkers would consider “out of the ordinary,” I think the choice is simple. The three advantages the left-tilt saws have can be easily overcome by machining bevels with one specific set-up on a right-tilt saw. Once you realize how fast, safe and easy this technique is, you will kick yourself for purchasing a left-tilt saw. Not only will bevelling be improved in every way but you will also enjoy the added benefit of always having your cursor reading accurately.
This set-up machines bevels on all the straight edges for a project, regardless of the width, length or angle of the work pieces. I have to readjust it for different thicknesses of material but it’s rare to have multiple thicknesses in need of bevel cuts in the same project. It takes a bit longer to set up (three to four minutes) vs. a left-tilt saw (30 seconds). However, with this one set-up, I bevel every edge that needs it, no matter what size, shape or angle the piece is, so it’s time well spent. If I only need to make one mitre cut, this might not be the fastest method, but if even three or four cuts are required, it’s a no-brainer. Make sure you cut all the pieces in need of bevelling to exact finished size before you start this set-up. This operation will simply machine the bevel on the edges that need it.
Another thing I like about this set-up is that the blade remains virtually buried in the sacrificial fence the entire time. It’s not out in the open where a momentary lack of concentration could be disastrous.
The final advantage is in the actual quality and crispness of the bevelled edge being cut. With any other bevelling method, the first cut (with the full thickness edge against the fence) often goes okay. It’s when you turn the piece around to cut the opposite side that you run into trouble. This is mainly because you’re now asking a razor thin edge to run against the fence and keep the entire panel perfectly aligned with the fence at all times; a tall task for less than 1/32" of material. This method has about ⅛" against the fence before being cut by the blade and this makes all the difference in the world. After the piece is cut, the same 1/32" edge will be asked to help keep the panel from shifting.
The Process.
1. Clamp a sacrificial fence to the main fence so the bottom of the sacrificial fence is about 1/16" to ⅛" lower than the top of the work piece.
Attach a Sacrificial Fence – The top ⅛" of the work piece should be the only portion overlapping the sacrificial fence, creating a cavity for the offcut to sit in.
2. Angle the blade to 45º (assuming you want a 90º finished corner) then raise the blade until the top of it is about 1/16" below the top surface of the work piece.
Angle the Blade – Adjust the blade to the proper angle and raise it so it’s about 1/16" below the height of the work piece.
3. Slide the fence (and sacrificial fence) over until it is about 1/16" away from the blade.
Adjust the Fence – Bring the fence as close to the blade as possible without touching the blade. The blade should still spin freely.
4. Turn the saw on and raise the blade until it protrudes into the sacrificial fence about ⅛".
On and Up – Turn the saw on and raise the blade until it protrudes about ⅛" into the sacrificial fence.
5. Make a test cut with a scrap piece. With a bit of practice you will only be about 1/16" off.
Test Cut – A test cut will tell you how you need to adjust the fence. You want the corner of the bevel to meet precisely at the top of the piece.
6. Readjust the set-up by moving the fence away from or closer to the blade. Re-test until perfect.
Perfection! – After some minor adjustments you’re ready to go.
7. With the set-up dialed in, make passes wherever you want a bevelled edge. This works for an edge measuring any angle. The offcut stays in the cavity until the next work piece pushes it through during the next pass. There’s enough room for it in the cavity, and unless you didn’t follow any of the first steps properly, the chance of it flying anywhere is virtually non-existent.
Run All the Parts – With your parts already cut to size run every edge that needs it against the sacrificial fence, removing a wedge from each piece. The offcuts sit in the cavity until the next piece pushes it out. Notice the blade is buried in the sacrificial fence, reducing the chance of injury.
One of the nicest parts of this set-up is that you can do any angle or shape (other than circular) with no additional set-ups.
I know what some of you are saying right now: “I can do that same operation on my left-tilt saw!” You’re right, you can. But the work piece will need to be placed to the right of the blade and fence and this is something most people will not be familiar or comfortable with. Not the perfect situation. And if you’re machining a large work piece, the use of an outfeed table and side supports are very helpful.
This operation may seem finicky at first but after you set it up a couple of times it will become second nature and will take only a few minutes. Now, with the bevel cuts taken care of, what else can a left-tilt saw do that a right-tilt saw can’t? Nothing. I thought so.
If you have anything to add to the right-tilt vs. left-tilt discussion visit our forum at forum.canadianwoodworking.com. –Rob Brown
Use of Canadian Woodworking's Website and It's Content
This website is presented with the understanding that:
The authors, editors and related web personnel are not responsible for the results of any actions taken on the basis of information on this website, nor for any errors or omissions;
This website is not engaged in rendering professional advice/services; and
Any and all content submitted by this website's users is in no way an expression of the beliefs or opinions of the owners, webmasters, authors and editors.
Canadian Woodworking disclaims all liability for any claim in relation to:
• any matters or factors outside of its control, including the availability or unavailability of the website and digital content due to the availability of the Internet, or telecommunications or other infrastructure systems; for any reasons including but not limited to power outages and maintenance.
The owners, webmasters, administrators, authors and editors, expressly disclaim all and any liability to any person, whether a user of this website or not, in respect of anything and of the consequences of anything done or omitted to be done by any such person in reliance, whether whole or partial, upon the whole or any part of the contents of this website. Please exercise caution when working with any tools or machinery. Follow common safety rules and precautions as outlined in any manuals related to the equipment being used. If advice or other expert assistance is required, the services of a competent professional person should be sought.
Use of Canadian Woodworking site and Forum
By posting on this site and forum, the poster grants to Canadian Woodworking Magazine/Website the unrestricted rights to use of the content of the post for any purpose, including, but not limited to, publishing the posted material, including images, in print or electronic form in a future issue or issues of Canadian Woodworking magazine or related Canadian Woodworking products, and to use the post for promotional purposes without further compensation, as well as the right to use the poster's name in a credit along with the post.
CanadianWoodworking never shares, sells or rents your information to any third party without your permission.
This statement explains how we collect information from you and what we do with that information.
What this Privacy Policy Covers
This Privacy Policy covers CanadianWoodworking.com's treatment of personally identifiable information that CanadianWoodworking.com collects when you are on the CanadianWoodworking.com site, and when you use CanadianWoodworking.com's services. This policy also covers CanadianWoodworking.com's treatment of any personally identifiable information that CanadianWoodworking.com's business partners share with CanadianWoodworking.com.
This policy does not apply to the practices of companies that CanadianWoodworking.com does not own or control, or to people that CanadianWoodworking.com does not employ or manage.
Information Requests and Use
CanadianWoodworking.com collects personally identifiable information when you use certain CanadianWoodworking.com services, when you visit CanadianWoodworking.com pages, and when you enter promotions or sweepstakes. CanadianWoodworking.com may also receive personally identifiable information from our business partners.
Personally identifying information is information that can be used to identify who you are such as: name, mailing address, email address. To enter certain areas of the site, you will be required to register and provide information about yourself. This information is for the purposes of Canadian Woodworking and helps us to tailor the site to best meet the needs of our audience.
CanadianWoodworking.com also automatically receives and records information on our server logs from your browser including your IP address, CanadianWoodworking.com cookie information and the page you requested.
CanadianWoodworking.com uses information for three general purposes: to customize the advertising and content you see, and to fulfill your requests for certain products and services.
Promotions
The personal information that we retain is what is provided by you voluntarily. We use it to send you information about Canadian Woodworking and its products or to correspond with you regarding your subscription. If you are a subscriber we need this information to be able to deliver you our product(s) and service your subscription.
By completing a form on this website, you will be able to receive email correspondence from Canadian Woodworking. These emails may include information on upcoming events or special offers for subscribers. If you do not wish to receive email correspondence please email [email protected] and ask to be removed from our email list. Every email that we send to you will include an "opt-out" from receiving future email correspondence.
Aggregate information is information that cannot identify you personally. We collect information on our subscribers that may be used in summary reports presented to our advertisers. This information helps them to better understand our audience and provide advertisements that are more likely to be of interest to you and your organization.
Our intention is always to gather information that will help us serve you better and never to gather information without your knowledge.
As with most websites, we do log web visits. This information, however, does not have a link to you personally. These logs help us understand the needs of our audience and the areas of our site that you do or do not find useful. When you simply browse our site, no personal information is being collected. We may disclose this non-personal information to third parties such as sponsors, clients or advertisers.
Information Sharing and Disclosure
CanadianWoodworking.com will not sell or rent your personally identifiable information to anyone.
CanadianWoodworking.com will send personally identifiable information about you to other companies or people when:
We have your consent to share the information;
We need to share your information to provide the product or service you have requested;
We need to send the information to companies who work on behalf of CanadianWoodworking.com to provide a product or service to you. (Unless we tell you differently, these companies do not have any right to use the personally identifiable information we provide to them beyond what is necessary to assist us.);
We respond to subpoenas, court orders or legal process; or
We find that your actions on our web sites violate the CanadianWoodworking.com Terms of Service or any of our usage guidelines for specific products or services.
Cookies
CanadianWoodworking.com may set and access CanadianWoodworking.com cookies on your computer.
Cookies are small text files that most Web sites, including canadianwoodworking.com place on your computer. Cookies help us identify your interests. They also prevent you from having to register repeatedly on canadianwoodworking.com or from repeatedly seeing the same ads.
Canadianwoodworking.com is not able, and does not wish, to use cookies to track your activities on the Web outside of our site. And no cookie delivered by us will interfere with the operation of your computer.
In cases where there are links to other sites, Canadian Woodworking recommends that you review their organization's privacy policy, as once you have left our site you become subject to the privacy and security policies of the new site.
Third party advertising
If you submit your name through a form on our website to request information from an advertiser or third party, canadianwoodworking.com is not responsible for any marketing or other use of your name by that third party.
Security
In certain areas CanadianWoodworking.com uses industry-standard SSL-encryption to protect data transmissions.
Changes to this Privacy Policy
CanadianWoodworking.com may amend this policy from time to time. By using this site, you agree to the terms of this Privacy Policy. Canadian Woodworking reserves the right to make changes to this policy at any time. Please check back periodically to review any changes.
Questions or Suggestions
If you have questions or suggestions please contact us.
