Top 10 Dust Collection Tips
Photo by Rob Brown
1. How much suction? Size your dust collector’s CFM (cubic feet per minute) rating for existing and future machinery. If two machines will be used at the same time you should
add the two CFM requirements together to determine your overall requirements. Also keep in mind that manufacturer’s numbers are intended for perfect scientific conditions, which woodworkers don’t work in. Err on the side of too much CFM.
2. Shorter is better – Try to reduce the overall length of ducts by placing the collector nearest to the center of the area. The longer the ducts, the more friction and turbulence is caused, reducing the effectiveness of your collector.
3. Wider hoses and ducts are best – Avoid narrow collection hoses/ducts; less than 4" isn’t going to provide much suction at all. Narrow ducts cause friction and reduce suction at the source of the dust.
4. Use blast gates – In order to close off areas or
machines not in use, the blast gate can be closed. This allows you to have multiple arms of dust collection ducts and direct the suction to where it’s needed.
5. Protect against static electricity – Grounded wires wrapped around the ducts will reduce the chance of shock and combustion.
6. Clean machines – Check machines periodically to ensure larger pieces of wood are not blocking airflow, and reducing the suction near the dust source. Table saws commonly have strips of wood fall into the dust storage area, but some other machines may also have this problem.
7. Clean clogs – Ensure no ducts/hoses are clogged, as any obstruction will affect the airflow in the ducts, and reduce suction. Corners are especially vulnerable to this type of blockage.
8. Maybe use more, smaller collectors – Consider smaller dust collection units dedicated to distant machines. If your space is large, having two dust collectors may help to increase suction, compared to using a long run of ducting.
9. Use auto on/off devices – By using a remote/automatic device that automatically turns on the dust collector every time you turn on a machine you will never be without dust collection.
10. Use a dust mask – Don’t be afraid to use a dust mask, especially when you’re creating lots of fine dust; i.e., sanding.
